Marlons Posted July 24, 2008 Posted July 24, 2008 Could someone let me know as to why the EPS light blinks when switching on the ignition??? After i start the car it goes off. Also today the car almost stalled when i tried cutting the stearing in full. Thanks Quote
Ruslan Posted July 24, 2008 Posted July 24, 2008 Could someone let me know as to why the EPS light blinks when switching on the ignition??? After i start the car it goes off. Also today the car almost stalled when i tried cutting the stearing in full. Thanks As far as i knows EPS motor Draws lot of power out from your car's Battery. that's why the car almost stalled when you try to turn it in full. Lacks power for Ignition. Hows your cars Battery condition? best advice is to check your cars EPS with your cars Agents. because EPS system is still new among our mechanic\Electrician people. Quote
Marlons Posted July 24, 2008 Author Posted July 24, 2008 As far as i knows EPS motor Draws lot of power out from your car's Battery. that's why the car almost stalled when you try to turn it in full. Lacks power for Ignition. Hows your cars Battery condition? best advice is to check your cars EPS with your cars Agents. because EPS system is still new among our mechanic\Electrician people. Thank you for the advice. I need to get it checked ASAP. Quote
Bugatti Posted July 24, 2008 Posted July 24, 2008 Is it a Nissan..? if so it could be two things.... but before I comment, I need to know if it a Nissan. Quote
Marlons Posted July 24, 2008 Author Posted July 24, 2008 Is it a Nissan..? if so it could be two things.... but before I comment, I need to know if it a Nissan. Its a honda ES8 Quote
