HI All
pls comment to my situation if u know any causes
When I started my car yesterday (corolla 122) there was an unusual engine miss and the vehicle vibrates and then the engine stopped
then I restarted and gave gas and then it was ok
this is the first time i encounter that kind of a situ
any ideas on this and any steps to over come this
thanks
Mike
HI All
thanks
Mike
I had the same problem yesterday morning and afternoon.
But, when i start the Car today morning, it was ok.
Is it because of driving in flooded roads?
engine "misses" can come due to several reasons.
--engine over or under heating
--oil in the plugs
--incostistant petrol supply(blocked pump,filter etc..)
--bad air filter
maybe the other guys could add to this
--oil in the plugs
--bad air filter
If those things has issues, you will get a continues misses even when you drive the car.
Issue is, this was happen in the morning and afternoon (when the engine was cold).
Its like this, in the first time you Fire the engine, it gives you a miss and then stops the engine. but, as soon as you turn it off, and fire again, then it gets start.
This happends to me yesterday morning and afternoon, but today morning, everything is normal and gave me a good start. <_<
Yes its quite similar to your symptoms
may be due to floods and rains
thanks
mike
Hmm.. perhaps Water in petrol tank can cause sudden hiccups.. :unsure:
And what about the Spark Plug Condition?
Edited by Ruslan
thanks
mike
Well, I think i'm safe now. There is no more Misses in the morning or evenings.
Maikk99 > Do you still have the issue?
