sira Posted November 20, 2008 Share Posted November 20, 2008 Hi anybody know how can i fix a RPM meter for FB13 car? I have seen some of them has fixed aditional RPM meter Sira Quote Link to comment Share on other sites More sharing options...
niro123 Posted November 20, 2008 Share Posted November 20, 2008 sira said: Hi anybody know how can i fix a RPM meter for FB13 car? I have seen some of them has fixed aditional RPM meter Sira you can fix it to the delco, ( the distributer) but only if the meter that you are fixing does not have sensor. the fb13 model comes with the sensor, if you have an ecu then its no game else, need to just have a look at it Quote Link to comment Share on other sites More sharing options...
sira Posted November 20, 2008 Author Share Posted November 20, 2008 (edited) niro123 said: you can fix it to the delco, ( the distributer) but only if the meter that you are fixing does not have sensor. the fb13 model comes with the sensor, if you have an ecu then its no game else, need to just have a look at it yes i got ECU in my car. so how can i find the signal wire for the RPM meter on ECU? also where i need to find a place to buy RPM meter? Edited November 20, 2008 by sira Quote Link to comment Share on other sites More sharing options...
sira Posted November 20, 2008 Author Share Posted November 20, 2008 (edited) sira said: yes i got ECU in my car. so how can i find the signal wire for the RPM meter on ECU unit? Is it ok to get form ignation ? also where i need to find a place to buy RPM meter? Edited November 20, 2008 by sira Quote Link to comment Share on other sites More sharing options...
charitha19 Posted November 20, 2008 Share Posted November 20, 2008 this is quite simple enough.. you can get the signal from the ECU or the coil pack that supplies power to the distributer.. Quote Link to comment Share on other sites More sharing options...
niro123 Posted November 20, 2008 Share Posted November 20, 2008 charitha19 said: this is quite simple enough.. you can get the signal from the ECU or the coil pack that supplies power to the distributer.. It is easier to get the signal wire from the coil pack, unless you are so sure of what you are doing better not play around with them, an incorrect connection will cause your delco to malfunction which will be quite expensive, ( you need to get the power throug a relay so that the wire dont heat up, and also better have fuse installed just in case), Mo***Cade near muttiah road behind the access towers , they have a set of good meters, Quote Link to comment Share on other sites More sharing options...
