Tyre Psi's For Colombo
Hi guys, I have been inflating my tyres (Nissan N16) as per the manufacturer sticker pasted on the door for 33 in front and 30 at the back. However recently I was told by a friend that Lal Alawatte had told him (for the same make of car) to put around 28 for all 4 tyres as Colombo road conditions were not good to fill up the tyres and that he would get better mileage. Now I have not had any issues that I know of by doing more in front and less at the back as per the manufacturer sticker. I have not changed the tyre sizes or anything, everything is as the car was bought new.
Question is, how accurate is what he is telling? Should I switch to underinflating all 4 tyres, or wud this damage the tyres and have negative impact on fuel?
Many thanks.
23 answers to this question
NO please don't. If you are happy with the ride stick with the manufacturers recomendations. I have never heard of under-inflating tyres to get better mileage. There are gurus and fake gurus. Nissan is the former ;)
Does sound a bit dodgy. It might give you more comfort in Colombo roads, but conventional wisdom says negative impact on fuel and tire wear.
same here...
the manual for vios says 33 for front and 30 for rear.
the ride will be bumby but surely better performance.
but my service station always pumps 28....
but wen i do it i do as as per the manual
I consider under inflating the tyre is a no... no, in every aspect. You’ll loose fuel efficiency, more wear & tare on your tires, less performance, poor maneuverability, the only thing you get is better comfort. If you want comfort above all of the above points, then have a slightly less Psi on your tires.
According to some, Maximum tyre pressure - 10% is the best in economy & performance. (i.e. If your tyre indicates the maximum recommended tyre pressure as 40psi, then 40-10% = 36psi) Ya… in CMB roads it may be too rugged. I used to air them to 29-30. But since then I got a new pair of rubber, I do a 32 all around. Slightly hard but not too much I would say. I’ve tested with a tankful for the new economy. Definitely better than it used to be. Not enough evidence to prove it though. I think the new set of tyre has a lot in that increase as well.
under inflation caused the the tires to set a bigger contact patch with the road resulting in more friction - that will obviously result in the need for more power to propell the vehicle , thus causing an increase in fuel consumption
its best to stick with manufacturer specifications, but the rutty roads around town are certainly a worthy enough reason to deflate a bit if you feel the ride is excessivly harsh
i think those tires offer a lower degree of rolling resistance hence the possible increase in fuel efficiency
The sticker on my P11 says, 2.2, 2.0 and 4.2, 4.2 kg/cm2.. An online conversion turns these values into,
2.2 = 31psi
2.0 = 28psi
4.2 = 59psi
Looks like the 4.2 value is a bit absurd.. Can't understand the sticker cos it's in Japanese and the only things I could read were these digits and the unit, kg/cm2.. :action-smiley-060:
Was wondering which are for front and which are for back and why would there be a difference in the left and right tires.. :blink: I currently have 17" low profiles and have been filling them upto 29psi based on advice from the A*W tech people, but now feel a little bit in doubt as to what the correct pressure is.. :unsure:
2.2 = 31psi
2.0 = 28psi
4.2 = 59psi
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=1
2.2 = 31psi
2.0 = 28psi
4.2 = 59psi
31psi - Front
28psi - Rear
59psi - Spare Tyre
Ok.. but what bemuses me is that there are two 4.2 entries... :blink:
Could you post a picture of the label? Somebody who understands Japanese will help you.
Managed to get a pic with my phone..
The Japanese is not all that clear but shows the four values which I mentioned.. Hope somebody can decode it.. <_<
that seems fine
when refering to the factory suggested pressure you need to take into account that fact that they aren't stock tires and the rim is a good 2" larger!
over inflating with rims that big on our rutty road is not a good idea
to be perfectly honest i run lesser pressure on 16"s
that seems fine
But, wouldn't our darned roads damage the rims if the tires are under inflated.. I thought, lower the profile higher the tyre pressure should be to avoid rim damages..
the greater degree of streess would be transfered over onto the suspension system by running with excessively high pressure
i wouldn't say underinflate but personally i keep it to just a tad bit under manufacturer specification
4.2 is the inflation pressure of the spare tyre when used at the front or the rear.
Thanks Jerryda.. It then boils down to 31 at the front and 28 at the back. To be on the safer side as Devinda mentioned, 30 at the front and 28 at the back would be ideal me believe. :jumping-smiley-013:
Also the specified spare tyre pressure applies for the stock (smaller) spare tyre, isn't it..? Currently I use the standard 15" tyre which was originally fitted to the car and later replaced by the low profiles.. So fill it up with 30 would be OK, I presume.
Edited by Jayathu
http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=72
http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=35
Edited by jerryda
i always stick with the manufacturers claims cos my car already has a rather bumpy ride. so im happy with 30 psi. but then again a 5psi increase would do wonders to ur fuel bills. cos there's a smaller contact patch with over inflated tyres and since the sidewall is held up as straight as possible there's lesser rolling resistance. which slightly increases the performance as well. not just that. you'll appreciate the sharper handling. on the minus side you'll have to live with a relatively bumpy ride and the tyre life could be slightly reduced and also u'll have less grip off the line. as for lal alawatte i think he's talking bollocks. i never liked his attitude anyways.
amen to that....the potatoland man is a bit of a hot head...must be all the tv fame...i've heard of him being rude and impolite to even his paying customers :angry:
thats exactly my point. i once heard he had a go at a customer and he's asked "do you know who i am?" and the customer said "yea alahena or sumthing"
