specs for Mitsubishi Jeeps produced in the 80's
Displacement, cc 2659
Engine model 4DR5
Max.power (Net), kw(PS)/rpm 100 ps (73.55 kw) / 3300 rpm
Max.torque(Net), N*m(kg*m)/rpm 22.5 kg*m (220.65 N*m) / 2000 rpm
Power density 13.7
Engine type Serial 4 cylinder OHCIC turbo
Engine information ACSD
Fuel system All speed governor attaching high pressure jet pump
Turbocharger Turbo with intercooler
Fuel type Diesel
LEV system (Low emission vehicle) No
Compression ratio 21.5
Bore, mm 92
Stroke, mm 100
Engine model 4DR6
Max.power (Net), kw(PS)/rpm 94 ps (69.14 kw) / 3500 rpm
Max.torque(Net), N*m(kg*m)/rpm 21.0 kg*m (205.94 N*m) / 2000 rpm
Power density 14.47
Engine type Serial 4 cylinder OHC turbo
Engine information
Turbocharger Turbo
Fuel type Diesel
Compression ratio 17.5
Bore, mm 92
Stroke, mm 100
Engine model 4DR6
Power density 14.36
Engine information
Turbocharger Turbo
Fuel type Diesel
Bore, mm 92
Stroke, mm 100
Both 4D55 and 4D56 came in as Turbo and non-turbo.
The turbo versions has the engine code 4D56T - the trailing 'T' denotes that its a turbo engine.
4D55 Displacement - 2346 cc
4D56 Displacement - 2476 cc
Turbo versions has different compression ratios
Oops sorry about the above post guys.
I have made a mistake in naming the thread, and have created a lot of confusion.
