hi to all you guys
my car is a swift manual sports version
it has nankang tires
my uncle said their is a shaking due to the high pressure of the tires
he said they are tube les tires
how can i check this out
how does one identify the correct air pressure needed for the tires
thanks
hi to all you guys
thanks
it's marked on the side wall of the tyre if it's tubeless or tube type....if there is no marking it means that it has a tube
hi to all you guys
thanks
Hi
the recommended tyre pressure for your vehicle should be on a sticker on the drivers side door pillar.
You should be able to tell if the tyres are tubeless by looking at the valve on it. The tubeless one has sort of a collar the seals against the rim and the tube one doesnt.
http://appleinternationalenggworks.com/bra...-tyre-valve.jpg
http://www.beadbreaker.co.uk/images/tyre_r...ore_removed.jpg
Note the collar around the valve
