Elvis_Pil Posted October 5, 2009 Posted October 5, 2009 Was no easy task, but wanted to try something a bit different. Also, thinking of offering it as a (chargeable) service to others, who want to upgrade their engines. What if I run on standard pressure..? No issue then, right..? If your running standard pressure- why have it at all? I speak from experience Dude. Quote
Bugatti Posted October 5, 2009 Author Posted October 5, 2009 If your running standard pressure- why have it at all? I speak from experience Dude. Currently I'm running 10PSI more than standard pressure. But as you say, if it's gonna mess up the injectors, what would you consider as a safe zone... What is the maximum, beyond the standard? Quote
pradfred Posted October 6, 2009 Posted October 6, 2009 I can help you out with that machan - I've got a digital speedo with a speed limiter remover! Its a brand new Pivot unit i bought for the Z which i never got around to installing - its still in the box funky little gadget cuz its supposed to show you peak speak each sun as well as quarter mile times etc. i've had it tucked away for sometime, so if your interested make me a sensible offer (does NOT necessarily be have to too close to the figure stated in the ad - thats the price i paid for it - still have the bill somewhere) and its yours Yo Devs, If Bugs doesent take it ....can I have second dibs on it? cheers PS : What the *** is that you've written on line 3 ? Quote
Devinda_Z Posted October 6, 2009 Posted October 6, 2009 (edited) PS : What the *** is that you've written on line 3 ? totally my bad - it should hav read as "funky little gadget cuz its supposed to show you peak speed each run as well as quarter mile times etc. " Edited October 6, 2009 by Devinda_Z Quote
Devinda_Z Posted October 6, 2009 Posted October 6, 2009 Yo Devs, If Bugs doesent take it ....can I have second dibs on it? suddenly everyone wants it! Bugatti took it off my hands on Sunday itself Quote
Elvis_Pil Posted October 6, 2009 Posted October 6, 2009 Currently I'm running 10PSI more than standard pressure. But as you say, if it's gonna mess up the injectors, what would you consider as a safe zone... What is the maximum, beyond the standard? No idea. But picture this: you got stock injectors with stock ECU giving commands based on stock A/F maps. Now put in a little device that tries to override this by forcing the injectors to do something that the ECU does not want them to do.. thats where the problem is. So unless you reprogram the ecu to accomodate the FPR- it really is useless. Then again if you do repogram the ECU- you can give the engine the more fuel- same result without the FPR Quote
Bugatti Posted October 6, 2009 Author Posted October 6, 2009 No idea. But picture this: you got stock injectors with stock ECU giving commands based on stock A/F maps. Now put in a little device that tries to override this by forcing the injectors to do something that the ECU does not want them to do.. thats where the problem is. So unless you reprogram the ecu to accomodate the FPR- it really is useless. Then again if you do repogram the ECU- you can give the engine the more fuel- same result without the FPR Hmm... you have a point. What you say is theoretically correct. But practically it works as it is. If I reduce the pressure to 20 PSI (stock pressure), on down shifting + throttling it is not that great. Doing the same at 30-40 PSI, you can feel a difference. Observation: Moment I increase pressure to +40PSI, check engine light flashes and on plugging in the scanner it shows "Fuel too rich" error code. Conclusion: I guess 40PSI in the maximum for stock settings. As you say, to go higher, the ECU needs to be re-programmed. Quote
Devinda_Z Posted October 6, 2009 Posted October 6, 2009 so is there anyone in SL who reprograms Mazda ECU's for performance? Outta curiosity does Zakie do Mazda's? Quote
Prami Posted October 6, 2009 Posted October 6, 2009 Great Work Bugatti. How about the test run and extra power? Quote
Bugatti Posted October 6, 2009 Author Posted October 6, 2009 so is there anyone in SL who reprograms Mazda ECU's for performance? Outta curiosity does Zakie do Mazda's? Errrr.. not sure Can you find out..? Quote
Devinda_Z Posted October 6, 2009 Posted October 6, 2009 (edited) Errrr.. not sure Can you find out..? you could PM him or email him directly - http://forum.autolanka.com/index.php?showuser=4366 Edited October 6, 2009 by Devinda_Z Quote
Elvis_Pil Posted October 6, 2009 Posted October 6, 2009 Hmm... you have a point. What you say is theoretically correct. But practically it works as it is. If I reduce the pressure to 20 PSI (stock pressure), on down shifting + throttling it is not that great. Doing the same at 30-40 PSI, you can feel a difference. Observation: Moment I increase pressure to +40PSI, check engine light flashes and on plugging in the scanner it shows "Fuel too rich" error code. Conclusion: I guess 40PSI in the maximum for stock settings. As you say, to go higher, the ECU needs to be re-programmed. upto you dude. run without it and see Quote
Upesh Posted November 13, 2009 Posted November 13, 2009 Guys, Is BJ5Ws comes with VVTI engine? Bugatti Do you still have this one with you? At the end of the day are you happy about the decition to convert it in to VVTI? What is the manu year and the reg no of the car did you do the conversion? (Please share the info only if you are OK with it) Quote
Bugatti Posted November 13, 2009 Author Posted November 13, 2009 Guys, Is BJ5Ws comes with VVTI engine? Bugatti Do you still have this one with you? At the end of the day are you happy about the decition to convert it in to VVTI? What is the manu year and the reg no of the car did you do the conversion? (Please share the info only if you are OK with it) Yes the BJ5W come with a VVTi (SVT - 'Sequential Valve Timing' in Mazda terms) engine (ZL-VE), but quite rare. You get both the manual and triptronic transmission. You can do a Wiki search on Mazda ZLVE engines. It is said to produce 130HP. Mine was 2001... very happy with the performance, after the conversion. Quote
Upesh Posted November 13, 2009 Posted November 13, 2009 Yes the BJ5W come with a VVTi (SVT - 'Sequential Valve Timing' in Mazda terms) engine (ZL-VE), but quite rare. You get both the manual and triptronic transmission. You can do a Wiki search on Mazda ZLVE engines. It is said to produce 130HP. Mine was 2001... very happy with the performance, after the conversion. Thanks Bugatti... I got a deal for 1.45M. It's a YOM 2000, VVTI one with manual gears. What do you think about the deal? Can you let me know the fuel consumption of the vehicle.. Thanks again... Quote
Bugatti Posted November 14, 2009 Author Posted November 14, 2009 Thanks Bugatti... I got a deal for 1.45M. It's a YOM 2000, VVTI one with manual gears. What do you think about the deal? Can you let me know the fuel consumption of the vehicle.. Thanks again... 1.45 is a good deal I would say... is it the sedan? I didn't do the conversion for economical returns.. but to harvest that extra power hidden inside. Properly driven, you should get 10 km/l... You could join the MFOC now..! (Mazda Ford Owners Club) Quote
Upesh Posted November 14, 2009 Posted November 14, 2009 1.45 is a good deal I would say... is it the sedan? I didn't do the conversion for economical returns.. but to harvest that extra power hidden inside. Properly driven, you should get 10 km/l... You could join the MFOC now..! (Mazda Ford Owners Club) It is a sports wagon. HQ series. 130 on the clock. 14.5 is bit high for me. What do you think about his offer? Quote
Bugatti Posted November 14, 2009 Author Posted November 14, 2009 It is a sports wagon. HQ series. 130 on the clock. 14.5 is bit high for me. What do you think about his offer? I sent you a PM.. Quote
Upesh Posted November 15, 2009 Posted November 15, 2009 I sent you a PM.. Its in Dehiwala. My bad. I made a bad choice by not giving advance to that guy. He closes out the deal for someone for 1.4 M. Anyway.. Thanks a lot Bugatti.... Quote
DevakaC Posted November 15, 2009 Posted November 15, 2009 Its in Dehiwala. My bad. I made a bad choice by not giving advance to that guy. He closes out the deal for someone for 1.4 M. Anyway.. Thanks a lot Bugatti.... I know exactly how that feels. When you really want a vehicle and a slight hesitation leads to losing the deal. We missed one like that sometime back but even up to date me and my dad talks about it. But Upesh not to worry man, everything happens for a reason. Quote
MRM Posted November 16, 2009 Posted November 16, 2009 i drove Bugatti's car on last saturday and it is very responsive . definitely can feel a noticable difference in power and the car revs up freely . Quote
Bugatti Posted November 16, 2009 Author Posted November 16, 2009 i drove Bugatti's car on last saturday and it is very responsive . definitely can feel a noticable difference in power and the car revs up freely . Now we need to drive.. or have a ride in Peri's car.. Quote
Upesh Posted November 16, 2009 Posted November 16, 2009 I know exactly how that feels. When you really want a vehicle and a slight hesitation leads to losing the deal. We missed one like that sometime back but even up to date me and my dad talks about it. But Upesh not to worry man, everything happens for a reason. Thanks man. Yeah.. That's true. Everyting happens for a reason. But need some time to realize it Quote
Pericles Posted November 16, 2009 Posted November 16, 2009 Now we need to drive.. or have a ride in Peri's car.. I might have missed something here. Why mine? I thought this was a Mazda thread? Quote
Bugatti Posted November 16, 2009 Author Posted November 16, 2009 I might have missed something here. Why mine? I thought this was a Mazda thread? Curious to know the power under your hood... Been in MRM's VZR and that thing is fast. Yours is said to be faster... any chance of finding out?? Refer my new thread. Quote
