The only place I know which use bead blasting is Colombo Docyard to remove rust from ship hulls :)
I've never heard bead blasting being used on vehicles :rolleyes:
many ppl have been wondering about this - anything from Sand Blasting to Soda Blasting , that can be used when restoring sheet metal, but come up with nothing substantial sadly :(
Thanks for the comment and I know it very well since I'm also in harbour. :rolleyes:
Anyway I'm looking for something like this Blasting
Wow it would be great if we also can get the same done.
find yourself, or make, a cabinet and get the bead and a blasting gun and do it! I'm sure a sheet metal shop in SL will make it for you for pretty cheap (look for plans on the web). Although you will need compressed air, so may not be the best unless you have a shop air compressor at home. I have the gun but since I don't have a cabinet, and I'm using crushed walnut shells, it gets really messy in the garage 'cos there's stuff flying everywhere and I have to wear a thick sweater 'cos it hurts when you get hit by flying walnut shell!!! ha ha
Edited by MeanGreenZ28
