Rattling Noise During Acceleration
Chris0628
Did you check your engine mounts ? It should be coming from the engine. but better to check.
Engine mount was replaced abt 2 weeks back & it was running very smoothly..... only thing i changed after that was Alloys & Tyres....
Hi Bro
if you have checked all the things mentioned, including diff/ gearbox oil, pls check ancillaries in engine ( compressor, idlers,water pump etc)
otherwise, it could be your big end bearings or something else on the engine ( hope not)
have you changed the engine oil on time
Hi Bro
i changed the timing belt, oil seals, engine oil, ATF & replaced rear shocks & swing arm bushes during the past few weeks.. :-) and it was running superbly...
as for the alloys.... well this noise was there (a little) before the alloys was changed also....
hi guys... i took the car to Stafford motors... it was a timing issue & they adjusted it free of charge.... now it runs well :-)
thanks everyone
I guess, Valve lash/tappet adjustment :D
Had the same issue after a head gasket replacement...
Edited by shanX
thanks everyone
So it was knocking/pinging due to pre-ignition (bad timing). It could even have been bad gas in your tank causing that. A lower octane than the engine is tuned for will cause this. Glad you got it fixed before it messed up your internals. Edited by MeanGreenZ28
