Hiran Ganegedara Posted July 20, 2009 Share Posted July 20, 2009 Hi all, I drive a Nissan SB-14 and recently I changed ATF. Since then the pulling power of the car has significantly reduced. It takes hours to overtake a vehicle specially in the high gears. It would be great help if I can get a clue about what's wrong. I'm planning to take the car to A*W for a checkup. Also are there any garages or mechanics specializing in auto transmission? Thanks in advance Quote Link to comment Share on other sites More sharing options...
0 virensti Posted July 20, 2009 Share Posted July 20, 2009 Hiran Ganegedara said: Hi all, I drive a Nissan SB-14 and recently I changed ATF. Since then the pulling power of the car has significantly reduced. It takes hours to overtake a vehicle specially in the high gears. It would be great help if I can get a clue about what's wrong. I'm planning to take the car to A*W for a checkup. Also are there any garages or mechanics specializing in auto transmission? Thanks in advance hmm whats the oil you used? it could make a significant difference in performance if you didnt use the correct oil. and I dont know any ATF places, but I suppose the agents would be the best place to go. Quote Link to comment Share on other sites More sharing options...
0 Hiran Ganegedara Posted July 20, 2009 Author Share Posted July 20, 2009 virensti said: hmm whats the oil you used? it could make a significant difference in performance if you didnt use the correct oil. and I dont know any ATF places, but I suppose the agents would be the best place to go. I used ABRO AT-150DXIII. Quote Link to comment Share on other sites More sharing options...
0 VVTi Posted July 21, 2009 Share Posted July 21, 2009 Hiran Ganegedara said: I used ABRO AT-150DXIII. Sine yours is a Diesel, have you got your engine/injectors checked up? Are you putting out a lot of smoke? D3 or D4 is what is used anyway, inspite of the brand name. Quote Link to comment Share on other sites More sharing options...
0 Hiran Ganegedara Posted July 22, 2009 Author Share Posted July 22, 2009 VVTi said: Sine yours is a Diesel, have you got your engine/injectors checked up? Are you putting out a lot of smoke? D3 or D4 is what is used anyway, inspite of the brand name. Shortly before the oil change, I took the car for a injector and nozzle cleanup. The car's not putting out much smoke except for in high revs. Quote Link to comment Share on other sites More sharing options...
0 Tikiri Posted July 23, 2009 Share Posted July 23, 2009 Its bit diffcult to judge that this may hv happen whether due to the ATF change or its a coincident. First try the basics, correct oil level, cable / accelerator adjustment etc.. Some times it can be in the pump as most pump service places do various gimmicks to reduce the smoke.. There is a specialized AUTO GB workshop in Pannipitiya as you pass Manchi factory about a kilo meter on the left when going from CMBO just one block behind high level road, forget the name but you ask any one its a big two storied work shop ask for Auto GB and Turbo garage. Quote Link to comment Share on other sites More sharing options...
0 ferrarif50 Posted July 23, 2009 Share Posted July 23, 2009 tikiri, the munchee factory is in makubura (near homagama). not in pannipitiya. is it before the upali factory ? im also looking for a good auto GB specialist these days Quote Link to comment Share on other sites More sharing options...
0 Tikiri Posted July 23, 2009 Share Posted July 23, 2009 Yes, u r correct, pass munch and well before homagama. Its within a kilo meter passing munchi on to your left from CMBO. he fixed few problems for me some time back and only specilaizing in AUTO GB's and Turbo. A name like Jayasiri or Laksiri , you can't miss it, its a huge workshop you can see it from the High Level Road, to enter through a by road. Quote Link to comment Share on other sites More sharing options...
0 ferrarif50 Posted July 24, 2009 Share Posted July 24, 2009 Tikiri said: Yes, u r correct, pass munch and well before homagama. Its within a kilo meter passing munchi on to your left from CMBO. he fixed few problems for me some time back and only specilaizing in AUTO GB's and Turbo. A name like Jayasiri or Laksiri , you can't miss it, its a huge workshop you can see it from the High Level Road, to enter through a by road. will see .... thanks bro Quote Link to comment Share on other sites More sharing options...
0 Hiran Ganegedara Posted July 24, 2009 Author Share Posted July 24, 2009 Tikiri said: Yes, u r correct, pass munch and well before homagama. Its within a kilo meter passing munchi on to your left from CMBO. he fixed few problems for me some time back and only specilaizing in AUTO GB's and Turbo. A name like Jayasiri or Laksiri , you can't miss it, its a huge workshop you can see it from the High Level Road, to enter through a by road. Thanks a lot. Will go there and see. Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 26, 2010 Share Posted February 26, 2010 Hiran Ganegedara said: Thanks a lot. Will go there and see. Were you able to get the issue sorted ??? Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 26, 2010 Share Posted February 26, 2010 (edited) Hi Everyone... thought of adding my issue to the same thread... hope u guys don't mind.... My EK3 @ 1st & 2nd doesn't pull well and sometimes the shift down from 3rd to 2nd has a jerk... i noticed this specially going up hill and when the car needs to shift down the get more power it hesitates & then shifts down with a jerk...showed it to my mechanic & he said to run it until it fails or get really bad & then to replace...... One other thing i noticed is when the A/C is on.. the car feels very heavy.... I NEED AN SECOND OPINION... need to know if there's a way to get it fixed (cost effectively ) Edited February 26, 2010 by Chris0628 Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 26, 2010 Share Posted February 26, 2010 Chris0628 said: Hi Everyone... thought of adding my issue to the same thread... hope u guys don't mind.... My EK3 @ 1st & 2nd doesn't pull well and sometimes the shift down from 3rd to 2nd has a jerk... i noticed this specially going up hill and when the car needs to shift down the get more power it hesitates & then shifts down with a jerk...showed it to my mechanic & he said to run it until it fails or get really bad & then to replace...... One other thing i noticed is when the A/C is on.. the car feels very heavy.... I NEED AN SECOND OPINION... need to know if there's a way to get it fixed (cost effectively ) what is the transmission oil you used? Quote Link to comment Share on other sites More sharing options...
0 Tikiri Posted February 26, 2010 Share Posted February 26, 2010 Why not try showing to the agents and get their opinion... Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 26, 2010 Share Posted February 26, 2010 isurujosh said: what is the transmission oil you used? got the oil changed @ the agents as soon as i bought the car May-09. They did the manual ATF change. Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 26, 2010 Share Posted February 26, 2010 Chris0628 said: got the oil changed @ the agents as soon as i bought the car May-09. They did the manual ATF change. i have an issue with my cefiro with a minor jerk felt at 1st to 2nd and a reputed bloke was of the opinion that it could be due to ATF used by previous owner and also their lack of attention to cleaning upon ATF change. he also said issue could be electrical as well. i am nevertheless going to meet him 2moro. will update you with my results. bdw i PM you, did you get it? Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 27, 2010 Share Posted February 27, 2010 isurujosh said: i have an issue with my cefiro with a minor jerk felt at 1st to 2nd and a reputed bloke was of the opinion that it could be due to ATF used by previous owner and also their lack of attention to cleaning upon ATF change. he also said issue could be electrical as well. i am nevertheless going to meet him 2moro. will update you with my results. bdw i PM you, did you get it? Thanks machan... pls keep us all updated on the progress.... & yes i replied ur message... sorry abt the delay Quote Link to comment Share on other sites More sharing options...
0 Tikiri Posted February 27, 2010 Share Posted February 27, 2010 On the Cefiro - Check the Speed Sensor, if it is gone or even if the the sensor is not reading properly this could happen, I am sure Nissan experts may add more.. Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 27, 2010 Share Posted February 27, 2010 Tikiri said: On the Cefiro - Check the Speed Sensor, if it is gone or even if the the sensor is not reading properly this could happen, I am sure Nissan experts may add more.. tnx so much tikiri. da mechanic had a look at my car and said it is a neglible very minor jerk caused due to the ATF(Texamatic) used by the previous owner (guy is very expereinced with so many cefiros and other cars in the same league). he also added that they had filled in too much ATF and reduced a little bit. i plan to put in a differnt oil leisurely. Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 27, 2010 Share Posted February 27, 2010 Chris0628 said: Thanks machan... pls keep us all updated on the progress.... & yes i replied ur message... sorry abt the delay i recommed you to take a second opinion with my mechanic Vasant in Wattala. he is a very honest chap and very experienced and educated too. my problem is not as same as yours. i did not have any pulling issues, it was only a very minor jerk on 1st to 2nd, so my solutions might not work for you. but i strongly suggest you get a second opinion from him. if u r interested i will give his number for you to talk. Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 27, 2010 Share Posted February 27, 2010 isurujosh said: i recommed you to take a second opinion with my mechanic Vasant in Wattala. he is a very honest chap and very experienced and educated too. my problem is not as same as yours. i did not have any pulling issues, it was only a very minor jerk on 1st to 2nd, so my solutions might not work for you. but i strongly suggest you get a second opinion from him. if u r interested i will give his number for you to talk. Cool...sure pls send me the details machan... need all the help i can get... cos planing on going to Jaffna & another long trip in April.... so need the car in tip-top condition Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 28, 2010 Share Posted February 28, 2010 Chris0628 said: Cool...sure pls send me the details machan... need all the help i can get... cos planing on going to Jaffna & another long trip in April.... so need the car in tip-top condition ok i sent you a PM. Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 28, 2010 Share Posted February 28, 2010 isurujosh said: ok i sent you a PM. thanks Quote Link to comment Share on other sites More sharing options...
0 isurujosh Posted February 28, 2010 Share Posted February 28, 2010 Chris0628 said: thanks oh he does not work on sunday. might not answer da phone today. Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted February 28, 2010 Share Posted February 28, 2010 isurujosh said: oh he does not work on sunday. might not answer da phone today. Yeah... called but no answer.... tomorrow i have the day off... so will call him in the morning & try to get it done tomorrow.... Quote Link to comment Share on other sites More sharing options...
0 Chris0628 Posted March 1, 2010 Share Posted March 1, 2010 isurujosh said: ok i sent you a PM. Got the car checked out by your guy.... drained & then flushed the ATF twice... added new ATF there is a huge diff... much smoother & so far didn't get that jerk during down-shift.... thanks for the contact machan... he seems to be a very genuine guy...gonna run the car for a while & monitor .. alrady did abt 30KM after the change... very happy with the results so far. Thanks again. Quote Link to comment Share on other sites More sharing options...
Hiran Ganegedara
Hi all,
Thanks in advance
26 answers to this question
