bhanu128 Posted August 11, 2009 Posted August 11, 2009 i think most of you would agree the breaks in 2nd gen hilux are not the best..so it possible to convert the rear break to disk? any help advice.tip etc are welcome... Quote
0 Malinda_um Posted August 13, 2009 Posted August 13, 2009 I've been told that you can install the rear disc brakes from a Prado into hilux. I don't know how if this information is accurate at all. Quote
0 Supra_Natural Posted August 13, 2009 Posted August 13, 2009 i think most of you would agree the breaks in 2nd gen hilux are not the best..so it possible to convert the rear break to disk? any help advice.tip etc are welcome... By second generation you mean the 1980's LN85? Personally speaking, I have a 1993 LN106 and have always felt that the standard brakes were damn good for a pickup truck, have served me well on more than one occasion. Quote
0 ravisam Posted August 16, 2009 Posted August 16, 2009 By second generation you mean the 1980's LN85? Personally speaking, I have a 1993 LN106 and have always felt that the standard brakes were damn good for a pickup truck, have served me well on more than one occasion. I had a toyota LN96 (Made in 1985) around 10years back. The break system was a single line meaning one pipe coming out of the brake pump and with a T joint it distributes to front and rear. I bought a used booster and pump od same size from a used shop and replaced. The new pump contained two lines and I transformed the available pipes of cab in to two lines. The brakes were perfect after that. Quote
0 bhanu128 Posted August 24, 2009 Author Posted August 24, 2009 mine is a 107 , well i will look into what u have suggested. thanks! Quote
bhanu128
4 answers to this question
