Hi Guys,
I down sized my wheels from 215/45R17 to 195/65R15 last week.. Gave up my old 17" and got a new set of 15" for the same prize :jumping-smiley-013: but the problem is, couldn't get a good set of nuts for the new wheels.. Now on the hunt for a good set and can any one help with an idea or two as to where I can buy some..
Thanks.
  Jayathu said:
Hi Guys,
Thanks.
I have also checked colored nuts for my Mazda. But couldn't find yet. JJ lanka has normal nickel nuts.
  Devinda_Z said:
Motorcade as always :)
they had the standard lug nuts as well as the fancy ones from Thailand or wherever
Have checked Devinda. Fancy lug nuts they don't have. Only nickel nuts.
Hmmm.. this is worrying.. Some one told me to check at the spot near the Dawson street roundabout. If not, may have to settle for nickel ones.. :unsure:
Hope I' not completely deviating from the topic.....I need to switch to a 14" set of wheels from my current 15" s (low profile for SL is a few years away!!). What kind of cost are we talking about if I do an exchange? (my tires are 1 yr old and the rims would get an 8/10 score :-) )
Well, in my case I exchanged my 17" wheels and the two rear tires (both the front ones were beyond any use) for a new set of 15" wheels for the same price. Had to only bear the cost of new tires... I think your exchange will go along similar lines.. But, why switch from 15" to 14", does not make much of a difference.
It does to me! I had 185/65/14 and went to 195/55/15. I miss the softer ride and I'm worried I might be damaging my car.
  Devinda_Z said:
hmmm wonder if Motor World in Dehiwala has any in that case :unsure:
Those days I have checked. But couldnt. Will try it again. :)
  Jayathu said:
Hi Guys,
Thanks.
Amila on Malay Street has a little tiny shop of sorts right opposite their main outlet - this joint had a few boxes of wheel nuts - chrome , Blue & Red along with a special tool for removal as these box nuts ( :unsure: i forget the correct term :( )
Oh.. Thanks Dev. ;) I got a set of nickel nuts from the place near the Dawson street round about last week.. Couldn't risk running about with a incompatible set of nuts. On hind sight, Should have waited a few more days..
I went that way a few times over the last week, but the horrendous traffic along Malay street and lack of parking space did not encourage me to have a look around.. Should go again and check.. Any idea about the cost? It is not too bad to keep an additional set of nuts. :D
since its Amila's you'll be going to you can pull into that empty-ish plot of land (which is their car park/ garage of sorts) directly opposite thier outlet on the other side of the road
no idea bat the cost- could have checked as i stopped by this evening also :(
