It means installing a Vtec engine in a car that didn't come with a Vtec engine. Yes, Vtec engines generally have a little more power but the main benefit is having power both in the bottom and top end by way of running different cam profiles based on engine RPM.
i heard only the head, distributor, ecu are changed along with wiering...etc ? But not the whole motor....pls confirm
It's not always the case... But I did it that way, cos rest of the engine was identical. had to change the sump too. But this would vary for each make.
Aka Vtec Mini-me. Anyways you can google and look up on other Honda specific forums for specific details of this process. There are DIYs with pics too ;)
  • 1 month later...
What does VTEC conversion of an NON VTEC Engine really mean ? ...details details details... :-)
and does it only mean more power ?
i have heard some mechanics saying that its possible. i think you will have to change cams, the ecu. not sure. pls correct me if im wrong. I believe that you will be able to find vtec engines in good condition as well.
you heard,,, after all these days? :o lol
