    Β
I think ur refering to that Silver ES1 its the JDM version and seems like a good deal...pls put ur extra attention on the EPS system and CVT box...do a thorough test run and if ur really hoping to buy..do a full check up @ da agents and go for it !
2.2 for a ES1 is a good deal with VTEC and CVT,EPS
Hi. No its an ES8. Saw it at a car sale in Pita Kotte.
The interior quality isn't that great. Leather was scraped (almost cut) on the drivers seat and the door upholstery on the driver side is cracked. But the car didn't feel too bad when driving.
Edited by Rebel
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
Hiiii.................
Is there a Much difference in fuel consumtion with regard to VTEC and EXI
and the performance...
thnks.... prasa
thnks.... prasa
performance hence market value, yes. not sure about fuel consumption..
hi guyss...
I went for full service yeterday.... one of there mechanic guys told me there is sme thing wrong in the radiator..
he ask me monitor the water level and if its ging down he told..
i might have to replace the radiator..
how much will it cost .... wher i can find recondition one.....
and price for a power steering rack...
thnks
hi guyss...
thnks
For a recon radiator and a steering rack go to hill street dehiwala US auto parts. steering rack cost you aprox 28000 Rs and no idea about the radiator. You may find in delkanda area also.
Putting nylon bush to the rack won't last long (Which agent does) better to go for a used rack. :)
Hi guys appreciate a little more help.
Is 2,125,000 a fair price for the below car
Honda ES8. Silver. YOM 2000. Registration 2005. No JR****. Mileage 95K. Auto. Leather seats.
Addtl Options. Fogs, CD player, K&N Air Filter.
Required repairs. Rear power mirror on one side. Cracked door upholstery(the plastic bit) on the drivers door.
No other visible repairs. Agent maintained but I have not seen the records. They are supposed to be available. Paint work in great shape.
Please help.
Hiii Guys......
there is a small leak in upper side of the radiator.. instead of replacing a new radiator...
is it a good thing to replace the upper part from brass( pittala)....
machanical guy told me that hell be able to replace the upper part with brass..
thnks prasa...............
Hiii Guys......
as far as i know it s not good to redo the tank. if its a small crack, try to use the araldite instead. my previous ek3 also had a crack on the upper tank near the inlet. that was sealed using araldite and the radiator worked perfectly ok until i sold it. to be on the safe side i showed that to upul too and he said not to worry.
hi guyss...
thnks
here we go... common rack issue of es8.
Pls tell me wheres that place is..
and a contact no of that person..
thnks for the quicl respond..
regards prasa..
regards prasa..
no place as such. any radiator repair guy would know to use araldite.
machan u know any good guy to do this thing..tell me a plc i have no idea..
thnkssss
thnkssss
text me 777-235603
Please help.
vtec engine? alloys? spoiler??
Radiators in new cars dont just develop leaks due to normal running, best is you check the whole cooling system as well after fixing it. Normally if the radiator top/bottle is cracked, they can be replaced with the original top which should be available in panchi (without having to replace the core)
Hiii Guys......
vtec?? then price should be ok
Little too much i would say. IMO 20.75-21.00 would be a good price.
Hi
Thanks for the reply.
To clarify it is a vtec engine. it has alloys. It doesn't have a spoiler.
Hi
yep..with all of them. check the condition of the tires and suspension since you will have to spend on them if they are not good. it will be an added cost.
Hiii Guys......
as elvis said...It could cos of another problem the radiator cracked...for example,the fan could be not turning on or off at the right times.
I'd avoid the brass job if I were you..they charge on average 3500/- for the job whereas you can find a recon radiator for about 7000/-...and the local brass finish looks damn ugly......check the usual recon places or contact Upul,he had a couple of recon rediators for sale last time I went to his place.
Brand new Spoiler cost only 35000 Rs at the agent. Painting is additional.
I'm lost.
I dont want the spoiler. I want the car..
bro 20lacks would be a decent price for it.The 2002 one goes for about 21 lacks.
And also check the suspension system.If its VTEC check the condition of the Multimatic gearbox and try to get its maintenance Records.It might give trouble later on If it isn't maintained Properly.And also Ive heard that there is something wrong with ES8 steering rack(Not sure).
1 of My friends bought a 2002 1 Manual 100000 on clock still no probs.But Its a Non Vtec Manual.
hi guysss.
In Es 08 s is it normal thing, that front wheels are getting heated.
i cant even touch da wheels after running 20Km on a average traffic (no break binding pro either).
pls send u r feed back..
thnkss............
Edited by prasa
