nadunr Posted March 22, 2010 Posted March 22, 2010 (edited) Hello friends, I am new to this forum, I need an advice from one of you guys know about vehicle emission testing and engine tuneups. The test result was "passed". However the guy who did the test suggested me to go for an EFI tuneup. What do you think? Do I need an EFI tune up? Or can I postpone it? How much will cost roughly? My car is a Toyota Starlet EP 82, I got this emission test done recently. Here is the result. _____________Limit__________________High Idle__________________Low Idle HC PPM VOL___1200__________________218__________________358 CO%___VOL___4500__________________1881__________________1134 CO2%___VOL________________________14010 __________________9330 O2%_____VOL_______________________0.090 __________________0.090 Lambda____________________________0.947__________________0.947 RPM______________________________2570__________________730 Fuel wastage percentage High Idle SLR per litre - 7.89 Low Idle SLR per litre - 8.80 Thanks......... Edited March 22, 2010 by nadunr Quote
0 Mani Posted March 23, 2010 Posted March 23, 2010 My guess is the guy is trying to take you for few bucks. If your car is running fine and this test indicates that it is otherwise healthy, you don't really need to do an 'EFI tune-up" IMO. Quote
0 jaga Posted March 23, 2010 Posted March 23, 2010 Fuel wastage percentage is towards high side. My one is 9cents and 8 cents.Also co% is high. Better you go for a tune up. Basically they will clean your throttle body and check sparking plugs. If you are closed to ethul kotte , there is a garage run by former toyota lanka formen at Angampitiya road and the Formen's name is Chandrasena. He does a good job for a resanable charge.All the running repairs of my wife's ep91 is done by him. Rgds, Quote
0 Ripper Posted March 23, 2010 Posted March 23, 2010 If you haven't done a tune up in a while. there's no harm in doing one. with all filters, plugs etc the agents will charge you about 14k if my memory serves me correct. I'm sure other joints would be cheaper. it's weird that you seem to be burning more fuel in low idle and not the other way around. maybe that's what prompted the testing joint people to suggest an EFI tune up. Quote
0 gunat Posted March 23, 2010 Posted March 23, 2010 Well, its definitely not numbers typical of a toyota efi- may just be that you need a new set of plugs, throttle body clean up and if really necessary, Fuel System Clean. Do you know the last time this was done? Quote
0 nadunr Posted March 25, 2010 Author Posted March 25, 2010 Thanks a lot guys, Just another query, which is better Toyota lanka or a Local garage? What will be the rough price difference? This drive green guy told me it cost about 3000 for the tuning. What about if parts are replacing (Im sure I will have to do) Would really appreciate your opinions. Thanks Quote
nadunr
Hello friends,
Here is the result.
Thanks.........
Edited by nadunr5 answers to this question
