Today i failed green test. I want to fully repair my engine.
1) What will be the price for doing that thing?
2) I want to know good garage near moratuwa
Can any one help me.
I want to repair it quickly as possible.
U mean an Engine Overhaul?
there's tilan motors. pm me if u want contact details. they do a good job.
Is your engine under compression? did u check with a good mechanic?
first, show it to a good mechanic and ask what needs to be done. don't go for a overhaul just because u failed the green test!
Don't just go for an engine overhaul as suggested. Just check the causes for failing the test. Just do the basics like having new air, diesel, filters. Clean / change injectors heat plugs etc.
But if you have under compression, less pulling power go for an overhaul
