July 19, 201016 yr Dear Sir, May we know the name of the advisor please? Sir, He is one Mr. Adikari from early German tec pass outs now service adviser for a leading importer.I had to get his permission to this post. Wijesinghe.
July 20, 201016 yr This I got from the WEB Q/A. My car is running rough, but the diagnostics show no fault, what can I do? Try pulling the ECU fuse. Remove it for at least 90 seconds. The ECU will then โforgetโ its previous settings and will โtrain upโ for approximately 4 kilometres before it essentially back to โNormalโ. (Actually, the ECU is โlearning/trainingโ all the time, based on the LAMBDA (oxygen) sensor and the pre-detonation detector, amongst other things.) If this doesnโt improve the roughness, you will need to diagnose the problem in more detail. Check your spark plug leads. There may be a fault with your fuel pump. You could have a faulty ignition coil.
