    Β
Can I pls have your expereince on below situation?
Recently I did my petrol car (2005 model) throttle body + injector (manual cleanup not that can stuff) cleanup and replaced s-plugs with platinum plugs. Reason to do all that was, I used to get 15+km/ltr km/ltr but it dropped about by 3km/l. After doing all above it has gained about 1.5km/ltr. Car pulls smoothly. Any caused why it didn't get to original status.
Thanks,
Sorry I seem to have miscommunicated it. It should be read as original 15+, dropped to 12.5, then after repairs got 13.5+.
Edited by Neville
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Thanks,
Hi Nevile
That is embarrassing ,fuel consumption to fall from 15KMPL to 3 and then to 1.5 KMPL :o
actually the mechanic has not identified the real problem on it he might have thought
throttle body + injector cleaning would solve it, but not that you might have any other problem or either he
has not done the job properly.go to a good mechanic mate.
Regards
sumith
Hi Nevile
Regards
sumith
Thanks Sumith. I miscommunicated the pciture. It is like this...original 15+, dropped to 12.5, after repairs 13.5.
If you are getting 13.5km per Litre.. on a petrol car.... you should be happy...
exactly :D
btw Neville....what's the car you drive?
those are very impressive figures!
and also...have you replaced the air filter? that clogged filter can affect fuel burn quite a bit
IMHO I think you have a leak in you're petrol tank :):P
That's a serious possibility lol, once I had to replace a leaking fuel line hose, which has been leaking for sometime :o
Thanks,
You might also want to check on replacing the Fuel Filters as well - Generally there is one in the tank and one in the Throttle Body unit depending on what Car your driving...
  • 4 weeks later...
I just want to share my expereince on this matter. Finally I manage to bring my km/ltr back to its original status. In my post, I mentioned that I replaced old s-plugs with platimum (B**h) set. As I could not find any other cause to km/ltr drop aftger doing all that I took the car to agent (Toyota), and they did all checks (by their intelligent scanner) -nothing was wrong and all readings were as it supposed to be. But the service advisor sugessted to replace the platimum s-plugs with what is recommended by Toyota (Denso normal plugs), as the heat range is different (mind you my earlier mech. referred the conversion table -from Denso to B**h...not at all to say the latter is bad, ok) in what I had put. So, it seems that even if the conversion table is referred, this particular property of the s-plug was affecting the km/lt.
Rgds,
Rgds,
Hi Navile
good Luck ... ! any way your fuel figures were not bad at all,but when you seen it at once you don't want to reduce it :) , Would like to know how mush it was costed for Platinum spark plug new set ?
thanks
Regards
Sumith
Rgds,
Hi Navile
thanks
Regards
Sumith
I have this feeling you're one of those guys who doesn't rev more than 2000rpm! ;) ...which is actually not a bad thing since you're getting awesome fuel figures.
Hi Navile
thanks
Regards
Sumith
It was Rs.4000+, and the normal s-plugs are about Rs. 450 each.
Rgds
so what's the car? under what driving conditions does it return 15 kmpl?
It is none other than an Allion :)
Well my driving habits are very sober...if I may say so...I belong to the community who who does not race nor do sudden deep acceleration...etc
Rgds
<!--quoteo(post=129847:date=Aug 18 2010, 11:59 PM:name=topgear)--><div class='quotetop'>QUOTE (topgear @ Aug 18 2010, 11:59 PM) <a href="index.php?act=findpost&pid=129847"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->I have this feeling you're one of those guys who doesn't rev more than 2000rpm! <img src="http://forum.autolanka.com/public/style_emoticons/<#EMO_DIR#>/wink.gif" style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> ...which is actually not a bad thing since you're getting awesome fuel figures.<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes you are correct. Why should (or how could we) use more than even 1500rpm on our roads. If done, it will only make you break frequently. There are lot to learn on 'how to drive your car' <img src="style_emoticons/<#EMO_DIR#>/wink.gif" style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> . The only time you may drive 2000+rpm is on inside the country outstaiton, when road is empty.
Rgds
Rgds
why should we use more than 1500 rpm? To get to where we're going quicker and not hold up the rest of the road. (especially if, as in my case, your daily driver is an old diesel truck)
How could we do this? By pressing that thing called the "Accelarator" a bit further forward than a quarter inch of it's travel... Don't worry, it won't break!
There are lot to learn on 'how to drive your car' ;) . The only time you may drive 2000+rpm is on inside the country outstaiton, when road is empty.
Thanks for educating us on how and where we "May" or "may Not" drive. Im sure all of us are feeling very enlightened by this <_<
and another thing mr.nevile.. when u are driving at that pace.. i hope to god u are on the left side of the road.. if you are one of those people thank u sir.. and u can merrily go at 40KMPH and no one will bother u.. i hope..
but pray to god if u are hogging the road and using the right side of the road for ur antics... i will defa sweep u to the left.. i hate buggers who drive like thier car is broken and hog the right side...
Edited by charitha19
At times I wonder why some people bother buying cars at all.... they are better off with a bicycle with a small basket on the handle.
I noted some 'intersting' comments coming out on my attempt to share the expereince.
So, if I have hurt anyone, sorry about it, but here is what my driving exepreinces are:
1. In the morning when I start driving rpm goes around 2500+ at 60km/hr until engine hits the right temperatur
2. Once engine hit the right temperature, 60km/hr works with 1200+rpm (in my car)
3. Our road speed limits (as I know), 60km in built-up areas, and 70km/hr in other areas. I maitian this all the time -if not an emergency -then I would use emergency (hazard) lights.
4. I wish I could drive on left track, but alas ! they are occupied by all sorts of road users who travel 1km - <60km/hr range
5. While maintaining the given road rules, if anyone ask the way, I quickly give with safety in mind
That's all I got to say...any other comments after this...you can enjoy.
Bye,
Yes you are correct. Why should (or how could we) use more than even 1500rpm on our roads. If done, it will only make you break frequently. There are lot to learn on 'how to drive your car' ;) . The only time you may drive 2000+rpm is on inside the country outstaiton, when road is empty.
Rgds
In my case, coz my idle is at 1100 and if I change at 1500, it'll drop too low and make the car shudder.
And quite frankly even if you are puttering around at 1500 unless you stay on the 1st and 2nd the whole journey, you still need to brake frequently. I know, coz I tend to putter around at 1500 on the 5th.
