Saber EDV Dump Valve Simulator V3
Fits ANY car
80w High output speaker
130db LOUD sound output (approx 200db on XL Edition)
Authentic Dump valve sound (Blow off valve)
High spec marine type LOUD speaker
Installation time approx 30 minutes
Easy setup comes with all accessories and connectors
XL Edition comes with x2 80W highoutput speakers
Get the loud dump valve or blow off valve without a turbo!
The fake dump valve simulator is the only dummy blow off valve on the market that not only gives you a genuine sound by using MP3 Technology but also activates and the precise moment using a micro switch behind the accelerator pedal. When you change gear and back off the accelerator, the system activates the LOUD air dumping sound from the high output speaker that is mounted anywhere under the bonnet.
:action-smiley-060:
Ha ha ha ha ha ha ha ha ha!!!!!!
The Exhaust Flame Kits
Compatible with virtually any vehicle with a single / Twin muffler or tailpipe. Our exclusive Exhaust Flamer kits feature many specialized parts that other Exhaust Flames kits just can't match.
How does the exhaust flames kit work?
When you activate the system using the push button switch, the control module will allow the vehicles ignition system to be momentarily interrupted. Unburnt fuel is then allowed to pass through the vehicles exhaust system. When this fuel hits the spark plug(s) mounted in the exhaust tail pipe, flames are created.
This will NOT be a good hit with the KMPL Gang of AL.... I mean...imagine all that unburnt fuel being burned off.... that will surely eat in to the Kms!
Honestly in my point of view this is the automotive equivalent of stuffing a sock down your trousers to make your genitals look bigger. But if thats your kind of thing use the firing kit of single cylinder engine, fit the spark plug near the tip of the exhaust, do the necessary wiring and grounding stuff remove cat and you are good to go.
And doesn't unburnt fuel harm engine internals? And exhaust components?
If I remember correctly, adv*nc* car audio had such a system advertised some time back.... But judging by their recent A/L reviews, I'd stay away from them and anything flammable.... :P
