prasa Posted September 23, 2010 Posted September 23, 2010 Hi guys.. In my 2001 es o8 When turning I've heard TUK TUK noise from near the front wheel. what would be the cause of this. (Rack end Issue???????????) what would be cost for this kind of a issue... Thanks and regards prasa..... Quote
Pericles Posted September 23, 2010 Posted September 23, 2010 Hi guys.. In my 2001 es o8 When turning I've heard TUK TUK noise from near the front wheel. what would be the cause of this. (Rack end Issue???????????) what would be cost for this kind of a issue... Thanks and regards prasa..... Most likely your CV joints are gone. No idea on cost. Quote
Bugatti Posted September 23, 2010 Posted September 23, 2010 Did the ES8 come with hydraulic or EPS..?? Quote
jaga Posted September 23, 2010 Posted September 23, 2010 Did the ES8 come with hydraulic or EPS..?? It is EPS. Prasa I think your problem is not related to the rack issue. If the sound comed while the car is moving on a damaged road, It could be a rack problem. How the tuk tuk sound comes? When you are fully turning the wheel while on the run, if sound comes def it is CV joints. Quote
prasa Posted September 23, 2010 Author Posted September 23, 2010 (edited) It is EPS. Prasa I think your problem is not related to the rack issue. If the sound comed while the car is moving on a damaged road, It could be a rack problem. How the tuk tuk sound comes? When you are fully turning the wheel while on the run, if sound comes def it is CV joints. hi thnks all... It jst cming in the first half... driving or idle.. Not a EPS one... Edited September 23, 2010 by prasa Quote
Supra_Natural Posted September 24, 2010 Posted September 24, 2010 It is EPS. Prasa I think your problem is not related to the rack issue. If the sound comed while the car is moving on a damaged road, It could be a rack problem. How the tuk tuk sound comes? When you are fully turning the wheel while on the run, if sound comes def it is CV joints. The ES Series came with both hydraulic and EPS systems FYI. JDM cars had EPS while the export specs (such as the SL market brand new cars) had the hydraulic set up. Get your facts straight. Quote
jaga Posted September 24, 2010 Posted September 24, 2010 The ES Series came with both hydraulic and EPS systems FYI. JDM cars had EPS while the export specs (such as the SL market brand new cars) had the hydraulic set up. Get your facts straight. Brand new imported es8 has EPS and sin imported es5 has hydrolic. Quote
Supra_Natural Posted September 24, 2010 Posted September 24, 2010 Brand new imported es8 has EPS and sin imported es5 has hydrolic. No it does not. The brand new imported cars also had hydraulic systems. At least, all the cars that came in from 2000-2004 had hydraulic PS systems. Not sure about the final post 2004 editions but im fairly certain they were Hydraulic too. EPS was only on the JDM cars. Quote
