jami Posted November 7, 2010 Posted November 7, 2010 When I driving the car in a downhill I stopped it a while and put the engine off. Applied the handbrake in P position, after I start the engine it get vibrate and whole the body get vibrate for a while. Why is this? This is not happened earlier Quote
Uditha88 Posted November 9, 2010 Posted November 9, 2010 When I driving the car in a downhill I stopped it a while and put the engine off. Applied the handbrake in P position, after I start the engine it get vibrate and whole the body get vibrate for a while. Why is this? This is not happened earlier Does this happen when car is in unbalanced position? I mean you double check it again when car is parked on a downhill. Don't know whether the issue has something to do with the fuel system. Because when a vehicle is in a not leveled position, fuel in fuel tank tends to gather to a one potion. Quote
jami Posted November 18, 2010 Author Posted November 18, 2010 Does this happen when car is in unbalanced position? I mean you double check it again when car is parked on a downhill. Don't know whether the issue has something to do with the fuel system. Because when a vehicle is in a not leveled position, fuel in fuel tank tends to gather to a one potion. yes it happened when the car is parked on down hill. and i always manage to retain the fuel tank with half loaded capacity. Quote
Sumiya Posted November 19, 2010 Posted November 19, 2010 yes it happened when the car is parked on down hill. and i always manage to retain the fuel tank with half loaded capacity. Hi Jami could be system overloaded with more fuel than required first time because cold engine require rich mixture always, after some time it will disappear because system will lean the mixture according to the O2 sensor info, thanks regards sumith Quote
jami Posted November 19, 2010 Author Posted November 19, 2010 Hi Jami could be system overloaded with more fuel than required first time because cold engine require rich mixture always, after some time it will disappear because system will lean the mixture according to the O2 sensor info, thanks regards sumith so it means this is appear to be normal?? Quote
Sumiya Posted November 19, 2010 Posted November 19, 2010 so it means this is appear to be normal?? Hi Jami Hopefully Yes, i remember at once it was very difficult to start my after i parked it towards Hill Up .don't have any experience with hill down yet. thanks regards sumith Quote
