damika Posted November 24, 2010 Posted November 24, 2010 Hai friends, i recently bought a honda civic ek3 rs ,when i fully fill up water for radiator after drive for a long distance,in extra tank half water is there.whats the reason its shoud happen.please give some ideas. thanks dami Quote
civicferio Posted November 24, 2010 Posted November 24, 2010 Hai friends, i recently bought a honda civic ek3 rs ,when i fully fill up water for radiator after drive for a long distance,in extra tank half water is there.whats the reason its shoud happen.please give some ideas. thanks dami How do you fully filled the radiator, Opening radiator cap and filled the water directly to radiator or Filled the extra tank?? Quote
damika Posted November 24, 2010 Author Posted November 24, 2010 How do you fully filled the radiator, Opening radiator cap and filled the water directly to radiator or Filled the extra tank?? open the extra tank & fill up the water dude Quote
MkX Posted November 24, 2010 Posted November 24, 2010 (edited) Dont use water use good radiator coolent. Edit: this is not the reason for water level change . But water is not good in long run. Edited November 24, 2010 by MkX Quote
civicferio Posted November 24, 2010 Posted November 24, 2010 open the extra tank & fill up the water dude Yes. That's the correct way. Leave for couple of rides and checked the level again. if the water level is not reducing noticeably I think it is normal. Quote
damika Posted November 24, 2010 Author Posted November 24, 2010 Yes. That's the correct way. Leave for couple of rides and checked the level again. if the water level is not reducing noticeably I think it is normal. but i ride lots of time & check it,but the extra tank water is reduce Quote
Pericles Posted November 24, 2010 Posted November 24, 2010 Dude, I dunno about the civic, but there should be a marking on the reserve tank marked with a max level you should fill the water/coolant only upto that mark. Quote
damika Posted November 25, 2010 Author Posted November 25, 2010 Dude, I dunno about the civic, but there should be a marking on the reserve tank marked with a max level you should fill the water/coolant only upto that mark. in the extra tank i pull the water in the mark level,after drive i find it water level is going down dude,please tel the reason Quote
damika Posted November 25, 2010 Author Posted November 25, 2010 please dear friends,please advice me...... Quote
heavyD Posted November 25, 2010 Posted November 25, 2010 If the water level goes down after a single drive, then you probably have a leaky radiator. Quote
damika Posted November 25, 2010 Author Posted November 25, 2010 If the water level goes down after a single drive, then you probably have a leaky radiator. no leake in the radiator,not single drive,if i drive long only this should happen Quote
jdnet Posted November 25, 2010 Posted November 25, 2010 no leake in the radiator,not single drive,if i drive long only this should happen That would mean that you have a really small leak that you would only notice the change after the radiator has been pressurized for a sufficient amount of time. For a short drive you probably wouldn't see a difference as it would not leak that much. Quote
heavyD Posted November 25, 2010 Posted November 25, 2010 no leake in the radiator,not single drive,if i drive long only this should happen It generally takes a few days of normal running for the water level to go down. If it happens after one long drive or if the level goes down quicker than usual, than I'm afraid you have a leak somewhere. Quote
Watchman Posted November 25, 2010 Posted November 25, 2010 before we all start thinking "leak leak" lets step back a bit.. maybe there wasnt enough water in the radiator and the cooling system and hence the extra water that was put into the reserve tank has now flown into the system, hence DONE WHAT IT WAS MEANT TO... Was the reserve tank empty when you filled it up? if so, your question is answered So, fill up your reserve tank again and see if it does down again. Quote
Pericles Posted November 26, 2010 Posted November 26, 2010 Personally, I think it might be slightly damaged cap. A short drive wouldn't heat the water and create enough pressure to leak from the cap, but a long drive would. Quote
jaga Posted November 26, 2010 Posted November 26, 2010 Yes water could evaporate through a tiny hole or a hair crack in the system or through the cap. Once I had the same problem in my ek3 and agent has found a very very small leak at the hose connection and they traced it while engine was running. Quote
pirana Posted June 7, 2011 Posted June 7, 2011 Yes water could evaporate through a tiny hole or a hair crack in the system or through the cap. Once I had the same problem in my ek3 and agent has found a very very small leak at the hose connection and they traced it while engine was running. Hai friends in my honda civic car,the radiator extra tank water is not pull my the radiator,i changed the radiator cap also,but still not pulling yet.what is the reason,any body help me. i am planning to put my car for some check up for stafford motors,they can short out my problem,wht about the ideal place for engine tune up & full check up. thanks Pirana Quote
miniace Posted June 7, 2011 Posted June 7, 2011 Hmm if the reserve tank level was within Max and Min and the radiator was also topped up, recommend you re do the process and run few times and see.caution -monitor the temp level during runs. If the level still goes down noticeably and not settling down within operating limits (Between Min and Max) , check for visual evidence of leaks.Then change the radiator cap and see.You may swap with your best buddies radiator cap and do a run during lunch break n see.Caution again when trying to open caps when temp is high. If the level still goes down,there ends the DIY period. Take the car to a qualified technician and do a pressure test and see.Anyways your case is not a big issue. MINIACE 1 Quote
pirana Posted June 8, 2011 Posted June 8, 2011 Hmm if the reserve tank level was within Max and Min and the radiator was also topped up, recommend you re do the process and run few times and see.caution -monitor the temp level during runs. If the level still goes down noticeably and not settling down within operating limits (Between Min and Max) , check for visual evidence of leaks.Then change the radiator cap and see.You may swap with your best buddies radiator cap and do a run during lunch break n see.Caution again when trying to open caps when temp is high. If the level still goes down,there ends the DIY period. Take the car to a qualified technician and do a pressure test and see.Anyways your case is not a big issue. MINIACE Dear Miniace, thanks for the advice,i several time check up like this.in reserve take i always maintain the levels,but not pulled by radiator,when i drive and check up the radiator in radiator coolent level is drooped.no leaks in radiator. when i ask the technician ,they told me clean the radiator & want to check again.is it correct. thanks. Pirana Quote
MkX Posted June 8, 2011 Posted June 8, 2011 Dear Miniace, thanks for the advice,i several time check up like this.in reserve take i always maintain the levels,but not pulled by radiator,when i drive and check up the radiator in radiator coolent level is drooped.no leaks in radiator. when i ask the technician ,they told me clean the radiator & want to check again.is it correct. thanks. Pirana I had the same issue about a month back. Did what miniace suggested. In short distance nothing happens. But when I was stuck in traffic and using A/C the temperature goes up. I issue was coolant not going back to radiator from reservoir tank. And observed reservoir tank getting over flowed. Changed the radiator cap and problem solved. Quote
toosea Posted June 8, 2011 Posted June 8, 2011 Also check the radiator fan. If it does not work heat and pressure will build up faster and any micro leaks will tend to leak more and also get bigger over time. Quote
pirana Posted June 9, 2011 Posted June 9, 2011 Also check the radiator fan. If it does not work heat and pressure will build up faster and any micro leaks will tend to leak more and also get bigger over time. i fully check up with a radiator,no micro leaks,the fan is working continually Quote
dreezone Posted June 9, 2011 Posted June 9, 2011 i fully check up with a radiator,no micro leaks,the fan is working continually Well check whether the fan is working at the full speed. Usually with time and friction build up the fan tends to slow. Quote
miniace Posted June 10, 2011 Posted June 10, 2011 Well check whether the fan is working at the full speed. Usually with time and friction build up the fan tends to slow. Some guys are funny!! MINIACE Quote
miniace Posted June 10, 2011 Posted June 10, 2011 What luck you have?? Changed the radiator cap and checked ? MINIACE Quote
