dinidusoft Posted January 3, 2011 Posted January 3, 2011 (edited) I am going to buy sv14,99 brand new,65XXXXX with newly replaced engine.how can i know the new price range??? Edited January 3, 2011 by dinidusoft Quote
0 bope Posted January 3, 2011 Posted January 3, 2011 One of my office colleague bought one for 15,90 which was on AL a white colour car about 2 months back. But I am sure you can buy one for around 15 lks if you do a bit of searching. Bope Quote
0 dinidusoft Posted January 3, 2011 Author Posted January 3, 2011 thanks a lot Bope.. that car is silver color one and can i know any special things need to check (i mean like lights or buffer)?? Quote
0 bope Posted January 3, 2011 Posted January 3, 2011 Don’t think I can help you much there… check the suspension, shocks and make sure that the new engine is registered with RMV. If the interior and exterior of the car is good then it’s a good family car to use. Bope Quote
0 dinidusoft Posted January 3, 2011 Author Posted January 3, 2011 thanks Bope...N do you the procedure of RMV?? is it too costly? Quote
0 scds Posted January 3, 2011 Posted January 3, 2011 I can't speak for SU14, but I had a SU 13 and my, that was one special car for me. never let me down that old girl felt like driving a battletank. these cars are heavy, so check the shocks Quote
0 Watchman Posted January 3, 2011 Posted January 3, 2011 thanks Bope...N do you the procedure of RMV?? is it too costly? You dont have to goto the RMV for it. Just do a physical check to see if the number on the engine block is the same as the one on the book. (if it is then there's nothing to worry in that department) Quote
0 dinidusoft Posted January 7, 2011 Author Posted January 7, 2011 hi all, thnanks for all reps. i bought nissan bluebird su14.65xxxx with very good conditions with new replaced engine.price 15.75. N specially bope.ur price range is true. Quote
0 dinidusoft Posted January 7, 2011 Author Posted January 7, 2011 can i knw good places for service and maintenance.what about modifications?? Quote
0 Simplelife Posted January 8, 2011 Posted January 8, 2011 can i knw good places for service and maintenance.what about modifications?? Hi Mate, I used to have an U13 (ARX) and I always took it to P*T S**P for the service.....What kind of modifications are you refering here? Quote
0 dinidusoft Posted January 18, 2011 Author Posted January 18, 2011 it is not only modifications?? i need to check the security system and air bags...sec sys not working properly and air bag light is ON always. any recommended place?? and nissan vehicle specialized garage??? Quote
0 Simplelife Posted January 18, 2011 Posted January 18, 2011 it is not only modifications?? i need to check the security system and air bags...sec sys not working properly and air bag light is ON always. any recommended place?? and nissan vehicle specialized garage??? Why don’t you take it to the agents? or else there is a Nissan specialized person in Kelaniya…do a search you would be able to find the address.. Quote
0 The Don Posted January 18, 2011 Posted January 18, 2011 My old mechanic told me, if the airbag light is on it's probably because the airbag ECU has developed a problem often because of water or humidity (unavoidable in SL). You can confirm it by plugging the car in to an analyser and getting the error code. The other problem is usually the sensors in the seat belt clips but I'm not sure if the Nissan has them. The airbag ECU on the SU14 is under the driver seat, not sure about the SU13. On the security system it might actually be cheaper to get one installed locally than try to repair the original Nissan unit. I found this out trying to fix the Mitsubishi system on my Mirage. 1 Quote
dinidusoft
Edited by dinidusoft14 answers to this question
