Ruslan
Everything posted by Ruslan
  1. If you can find the Part number, try amayama.com as well.
  2. Montero Sport? well, it's worse than Fortuner IMO. less bells and whistles. previous Gen was far better specially the V6. Diesel one feels underpowered.
  3. Out of the List does the BMW X3 XDrive available in SL? thought only the 2WD available here. True Fortuner is a good buy. if i remember correct, TL is gonna launch New RAV4 here soon.
  4. Parking under trees is a big No No, sometimes the leaves might clog the drain paths in the firewall surrounding and can cause corrosion which is expensive to fix.
  5. Aren't those too whitey for fogs? you could've used them for Headlamp (Hi Beam) imho.
  6. Dont think it willl be an issue for SL Buyers
  7. Thanks iRage for the Explanation. yes you are correct. it should be B platform. so the new B Platform sits lower than MC platform (plus new MC platform)? which is previous Corolla (140) and new (170 - International) based on? reason why the new JDM Axio is lower in Dimensions and different setup suspension for rear (Coil and Shock sits separately like in Yaris / Belta).
  8. Yep, in fact Honda Grace is JDM version of Honda City. New Axio Hybrid is Based on Belta.
  9. Corolla Altis came with either 1.8L 2ZR-FE (Dual VVT-i) or 1.6L 1ZR-FE (Dual VVT-i). some of the JDM specific Allions and Premios came with 2ZR-FAE (Valvematic) Engine. i think DVVT and Dual VVT-i is two different technologies / tradenames (Although there might be similarities)
  10. Ruslan replied to mdinuth's topic in General
    This is doable in most premios, allions and prius as some of the grades of these vehicles came with cruise option (most of the time car came pre-wired and ecu firmware came with cruise option.). If the car is pre-wired, then it's matter of installing the cruise stalk with correct part numbers.Edit Checked the part catalog, non of the models came with cruise option for axio hybrid (NKE 165). Since this new axio is a b platform (belta platform) model, toyota might have moved these options to larger cars like camrys and premios. However Cruise option was available on previous Axio (141) models.
  11. Did the same trick with BG44K (available @ laughs). Switched OD off and driven in high rpms.
  12. According to Thel higannas, you'll get additional kmpl.
  13. Same Body with 24-105 L. got a Black Friday offer (B&H) while was in US. 24-105 L is used as a overall lens and Tokina 11-16mm for wide and 60mm Canon Macro for both Portrait and Macro.
  14. Could be "Battery air intake vent"
  15. That's absolute Beauty! Congrats Supra!
  16. Advise you to Drop a mail and get it clarified from amayama, believe that will be the cheapest option. plus in Panchi shops, they'll sell the Entire Fuel pump Assembly and not certain parts of it (Other than the filter which cos you around 6000/-). weeks ago i was looking for Screen Filter (a.k.a Fuel pump Filter) but that part was not sold separately and have to order through amayama.
  17. Even though they mentioned saying fuel sensor, it will be the same part if the part number matches. Similar incident happened to Member Rumesh when he tried to get down Throttle position sensor.
  18. Did you try with Amayama?
  19. Ha haa ... better stay away from "Lady Driven" Vezels..
  20. If it's a Premio, will it be 1.5 or 1.8? 1.5 will be little bit Underpowered, but that's just me.. Found that 1.8 seems pretty nippy.
  21. Guess, this is a Trial run by the Chinese Engineers to see how they (S12) perform in local conditions. hence the Chinese guy in the Cab.
  22. AFAIK, Tom tom units doesn't work here, you could use Garmin units with OSM Maps, i'm using my Garmin NUVI unit (Which I've used back in US) with OSM Map. it works wonderfuly and it includes custom POIs.
  23. There could be a leak in the system, system detects the low pressure and cuts off the power to compressor. Check your ac with reputed place.
  24. I too encounter similar issue. Water supposed to drain near fender liners but drain hole is clogged with debris and plugged. Had to remove wiper arms, plastic cowling along with rubber seal. When you remove, make sure not to damage plastic retainer clips, as they are sometimes not available locallly (had to import through amayama). What i did was use a small plastic cable to clean the drain path and wash. Make sure to close fresh air intake or else water will drip inside. Lessont learnt : never park your car under trees. Repainting faded paint is much easier than repairing rust.
