Twin Turbo
    51
  1. Twin Turbo
    4dr5 sound
    Check your engine oil level.
  2. Hi, toyotas have a 82'c t valve fitted from the factory,.. Taking into account the age of the vehicle,..you might wan check the valve for proper operation and replace with new coolant,..
  3. 1. Check gear box oil level.
  4. Are the batteries connected in series or parallel ?
  5. You might have to buy a complete used dash.
  6. Hi, 3if you're prepared to re invent the wheel, yes . it will be cheaper to get jap parts and convert.
  7. Hi, Apart from system checks + upgrades , you might want to look at FM signal boosters for your car as signal strength is less as you get away from Colombo,..
  8. Hi, before you take our car apart,.. re fill the fuel tank from a different fuel station,..There's a poszibility of contaminated fuel,..
  9. The re gap must be done without touching the center electrode,..any hoo,.. since the gap is ok,. ,guess there's nothing to do,..
  10. The sparks , although old look serviceable,.. just re-gap the things to speck and use them,..
  11. Sorry to say, Overhaul is not a part of general maintenance,.. but your van is not new. Replace the air filter , as the mileage is just an optimistic indicator, better not base your decision on that alone. check under the engine for possible oil leaks.
  12. Take the car to the dealer so they can not help you.
  13. Open rthe bonnet with the a/c on,.. and check the cooling fan is working,.. and the free flow of air is not restricted,..
  14. more cost effective to get central A/c, and cheaper to run,.
  15. Hi, Start by lubricating the door lock
  16. Hi and welcome to AL. Looks like the sun exposure finally has taken it's toll on your car. You'll have to look for a re-co dash instrument cluster.
  17. What ever you do, you'll need a carb overhaul kit for that . Also note your carb is off a Toyota. Also keep in mind that what ever you do, you'll have to get your car tom pass the emissions test when you get it on the road,..
  18. Hi, start by checking the fuse,..
  19. Hi, and welcome, Congrats on your new car,.. Yes, you have been advised,.. use regular petrol get a fill from your neighbourhood station and drive,.. although Ethanol increases the RON of petrol, your vehicle may not need it. Disclamer,..do research on previous posts on fuel quality and contamination in SL. Wishing you Happy Motoring,.. TT.
  20. WELCOME TO AL. Congratz on your first car,.. If you want efficiency, get a Mira, but you should get some decent consumption when compared with a regular SUV. Good luck. TT.
  21. Cut the existing ones and re-thread?
  22. Hi Welcome to AL,.. The blinking light indicates the car is immobilised. Try starting with another key,..
