kush
Everything posted by kush
  1. I had a 1.5L EX it had a bit more different engine note than a typical Jap. But not a hum Averaged 8-9 in city 15-16 outstation. This was pre highway era
  2. If you are using octane booster you will have to use it every time you pump 92. You will need to mix the booster in right proportion to boost the octane by 3 numbers. Container will tell you on the proportion required. Generally it is around one container for 50 liters for 2-4 number boost.
  3. kush replied to NASk's topic in General
    agreed, Only very few of what you mentioned are on the road hear. I'm sure any one who owns them know a thing or two about the fuel requirements. For over 30 years of running vehicles in SL I was may be fortunate not to have any issues with fuel quality. Not even a clogged filter. The only time i recollect of the bad fuel was couple of years back when there was a bad stock where fuel pumps in both stations and vehicles got busted. That had nothing to do with the octane rating but rather foreign substances that should have not been there which could even happen on 95. Yes there is lot of talk about 95 and 92 having less ratings. I believe it could be the average rating and there is a possibility of +/- 1-2 difference in a lab test. So far I have not noticed any running issues with either 92 or 95.
  4. kush replied to NASk's topic in General
    There is a big book that come with your car which is generally in your glow box or compartment under your driver/ passenger seat. If you care to read it that will give you the fuel requirement of your car. If it is in Japanese please use google translate. I have yet to come across any Japanese domestic model that required 95. Most of them run on regular octane which is 89-93 in Japan. This includes Turbos like CHR, Swift Turbo & CRV. (Personal and family experience, we have been running on 92 for the last couple of years with absolutely no issues) Your Euros and UK imports may need 95 as they are generally design to run on 98 and will run on 95 with little power / economy loss. As mentioned please refer user manual. Even if you pump 95 your car will not self destruct immediately. For a start it will start knocking if the electronic timing adjustment go out of range. You might get engine indicator / waning messages. A octane booster should solve this issue. You generally mix one can to a full tank of approximately 50 liters. (again read instructions in the can for the mix ratio) If your car is running on 92 without knocking or power/ economy loss most likely it is designed to run on Regular/ 92. There is no correlation on fuel quality and Octane rating. High Octane fuel has more additives to reduce knocking and hence the higher cost. In SL most of the people has this misconception that higher the price better the quality and hence has been wasting money on 95 for no reason.
  5. There is a big book that come with your car which is generally in your glow box or compartment under your driver/ passenger seat. If you care to read it that will give you the fuel requirement of your car. If it is in Japanese please use google translate. I have yet to come across any Japanese domestic model that required 95. Most of them run on regular octane which is 89-93 in Japan. This includes Turbos like CHR, Swift Turbo & CRV. (Personal and family experience, we have been running on 92 for the last couple of years with absolutely no issues) Your Euros and UK imports may need 95 as they are generally design to run on 98 and will run on 95 with little power / economy loss. As mentioned please refer user manual. Even if you pump 95 your car will not self destruct immediately. For a start it will start knocking if the electronic timing adjustment go out of range. You might get engine indicator / waning messages. A octane booster should solve this issue. You generally mix one can to a full tank of approximately 50 liters. (again read instructions in the can for the mix ratio) If your car is running on 92 without knocking or power/ economy loss most likely it is designed to run on Regular/ 92. There is no correlation on fuel quality and Octane rating. High Octane fuel has more additives to reduce knocking and hence the higher cost. In SL most of the people has this misconception that higher the price better the quality and hence has been wasting money on 95 for no reason.
  6. I used 92 throughout the time I had my EX from 2008-2011 did approximately 75K km without any issues. There was no noticeable power loss or economy. Mine did not even needed a throttle body clean up or a tune up that were required by most of the EXs serviced by the agent.
  7. We have a Wagon R which does around 13 - 15kmpl in the city when driven with blatant regard for fuel economy. So in my view your Vitz is a better option
  8. Get your battery shop to give a backup power through a parallel battery and swap the new one. They usually does this with new vehicles.
  9. Super diesel not sure about the sulfur content of IOC ex
  10. If it is your only car/ daily driver stay away
  11. Actually the last set of shocks I got from T**S were for my parents 141 Corolla they were perfect fit. Bought over the counter with only vehicle model and year.
  12. Agree with Mr. Sylvi even I have been dealing with them may be for over 30 years now never had any bad experience. I'm not trying to trying to justify giving the wrong part. Sometimes when they do not have the exact part they tend to provide a compatible unit. However they advice your to bring the old part to ensure that it measures right. In hindsight knowing the part may be different, either you or the mechanic should have compared the with the old part before fixing it.
  13. I have a POCO X3 NFC. Bit of a heavy and bulky phone over my previous Galaxy M30S Did not see much of a difference over AMOLED of the M30S on colour accuracy. 120 Hz on the POCO is better if you are into games. POCO is a faster phone and has better chip set and does not lag when gaming like the M30S Bit concern on data speeds as there were few issues reported. Do not know whether it is the phone or our service providers.
  14. Totally agree Had a CE100 and now a NRE-210H. Brilliant everyday car
  15. I feel your pain i went through the same situ few years back. Luckily for me they had the part in stock.
  16. This is a common problem with Kia. Throttle body get carbon deposits and the sensors gives faulty readings. Can goes in to limping mode and will not rev above 2000 rpm. Cleaning the throttle body some times rectify the issue but Kia recommends replacement especially if the car is under warranty. If you do a third party repair it might nullify your warranty. Suggest you get Kia to do a throttle body clean until they get the spare.
  17. Each charge was about 25KWh as i was keeping the battery between 20-80% So there was about 500 units over my usual consumption of 200 units. Instead of Rs. 42 per unit i was paying Rs. 13 for my EV charging However I lost on the initial cheap units up to 90 which believe was around Rs. 1-2 K. Now my bills are around Rs. 7-10K depending in use of a/c in the night after 10.30 You can get the rates from CEB site and work out how it will work according to your consumption. If you generally exceed 250 units TOU will be cheaper as most of the additional units over 180 will be charged @ Rs. 26 instead of Rs. 42. You need to manage use between 6.30 - 10.30 in the evening.
  18. I converted my billing method to Time of Use (TOU) when I had my Nissan Leaf. Where you are billed according to what time you use i.e. from 5.30 a.m to 6.30 p.m. Rs 26, 6.30 p.m. to 10.30 p.m. Rs. 54 and from 10.30 p.m. to 5.30 a.m. it was only Rs. 13 Car did 4-5 km / KWh which translated to around Rs. 3.0 per km Sadly no decent electric cars now so I had to replace it with a Wagon R.
  19. These taxes are collected by insurance companies. I have always paid them to them apart from the 1st one which you pay when you initially register the car/ SUV..
  20. This is absurd. There is no tax for computers in SL. They only charge PAL which is 4 or 5% of CIF I paid approx Rs. 12K on a Computer valued Rs. 240K (CIF). It came direct with full invoice value declared by the seller. Double checked to on the duty through a contact in customs who confirmed that duty was correct.
  21. kush replied to iRage's topic in General Automotive
    Do agree on the looks Rear quarter panel remind me of Nissan Looks as if they are moving away from 911 styling clues to more SUV/ Hatchback looks.
  22. I had one from A*** T**** for the last 15 year with only one service to replace a pressure valve around 4-5 years back. It is a 200L with copper tube and pipes.
  23. Duty will be very steep as the car is less than 10 years old. It may be not worth at cost + duty Please get documentary evidence on the duty to be paid before you jump. Or better still you quote for price + duty and let them pay the duty and transfer the vehicle to you. Good luck
  24. It says Gasoline Additive made. Branded Porsche. No other clue in the container other than safety infomation
