Ripper
Everything posted by Ripper
  1. TUAN MOTORS. 12 Jesmine Park, Narahenpita Road, Nawala dont have a number for them.
  2. I bought one from amazon...had it for a good 3 years or so now. use it to keep my bike battery in shape and the occasional charging of the truck battery. Held up pretty well. http://www.streetwizeaccessories.com/car-accessories/Battery-Chargers-~-Testers/1/all-categories/0/1/?page=1 thats the brand but the model i got seems to have been discontinued. And afaik....you can't buy it in SL. at least not the float charger. You might be able to find a jump starter though
  3. tuan motors nawala should be able to do the servicing, tuning bits. imho, most of the things you want sorted can be be done DIY. The only thing that needs bit of attention is the carb tuning. Nikko motors rajagiriyra and shops in maligawatta should carry things like pads, cables, filters etc
  4. yep. same here. i do it every oil change. cheap insurance!
  5. only way for things to get ejected through exhaust is either thing went through the air intake or it was stuck in the exhaust. oiil filter change would keep pebbles in the crankcase
  6. I had a similar issues with my ford. My model didn't have the hand pump at the fuel filter and it took a few cranks to get the motor running. And the truck would stall out after running a good 100metres or so after driving off I traced it down to two issues... One was a vacuum lock. Simple the diesel tank vent was blocked and as the fuel was getting used, air was not filling into the tank to take it's place. When you open the gas cap, you can hear the air getting sucked in. Managed to clean that vent and the vacuum sound problem was resolved. And the truck wouldn't stall out after driving off. Still the starting problem was there. So that issue was... Your fuel filter housing/hand pump unit has a valve. simply when fuel gets filled into the filter this valve makes sure it doesn't get siphoned back to the tank. So next time you start the engine, the filter housing is primed with fuel and injectors get fuel to start the engine. When the valve eventually fail, fuel filled in the filter gets siphoned back to the tank. So it takes a few cranks or priming via the hand pump to get the motor going. To my knowledge the only way to fix it is to replaced the manual pump/filter housing unit. You can get a non-jap new unit for around 2000 bucks. A used jap pump will cost the same or at times more.
  7. if there is body work to be done (tinkering) and if things like windscreen etc have to come off, the costs shoot up high. Some painters tend to respray with just masking things out... Simply the term "full spray" is different from painter to painter.
  8. mostly this happens when our guys do the wiring. and not all speakers have that fail safe of having two types of pins.
  9. isn't this the same guy who made the first wind powered car? name sounds familiar and the base model for that was a chinese electric car.
  10. Great thread mate! too bad you had to let her go.
  11. should be a great race today. especially after what happened in Pannala! Good luck to all drivers and hope for a clean race!
  12. you can drive fully tinted until your luck runs out eventually one day. has happened to quite a few of my friends! legally...you can't have any tint on your front shutter. rear shutters can be fully tinted. Windscreen can have the top strip tinted.
  13. holy cow? really???? PP's dad is a thug or summin? and how can he threaten to ban anybody else for making a legit protest? those procedures are there to sort out issues officially without having to resort to 3rd class fist contests! Jeeez!!!
  14. suppose this involves Pasindu then! I hope they didn't have this altercation with DD
  15. SLGT seems to be tightly contested! Hope they'll show it on the tele
  16. those rates are when the maintenance and stuff are attended to by the owner and not the renter isn't it?
  17. bummer! that sucks! unfortunately quite a few reputed places in colombo too are guilty of this!
  18. you do realize that this is a 3 year old thread!
  19. this is the first time i've heard of a fuse box "Wearing off" usually, some contact cleaner can sort out deposits issues. any chance of a picture of this unit? Assuming this is the fuse box in the engine bay... a fuse box from another car should be able to be "jerry-rigged" in.
  20. Ripper replied to wjkalana's topic in BMW
    run a search. discussed plenty times before
  21. Ripper replied to wjkalana's topic in BMW
    you just need to find out which bulb your car runs and find an appropriate HID conversion kit. you get high beam on HID;s and bi xenons too. Without projector lenses it wont be perfect but these days, plenty people run HID's on stock halogen housings. look at weekend classifieds for installing places if you dont wanna do it DIY. also plenty threads on this topic so running search might have saved you from the troll!
  22. old post
