Ripper
Everything posted by Ripper
  1. hapoi...bloody muspainthuwa! thook!
  2. no worries matey!
  3. very good little bike. have not owned one myself but friends have had them sometime back. if it's been looked after well, shouldn't give you much trouble. 2 strokes tend to need top end overhauling a little more frequently than your average 4 stroker. Since it's a bit of an older bike, i would check the mechanicals well. also things like shocks etc. Check the body for crash damage, most these bikes are not ridden slowly...
  4. if you plan on keeping the unit for a long time and using it extensively...best would be to bite the bullet and go for a good brand. Or for weekend projects and the likes, a cheap one should be quite ok. Most paint joints in sl dont use expensive spray guns. Maybe velocity or JDnet can chime in with better info
  5. discucessed extensively.... run a search!
  6. Hey BlackR6 Any luck with them racing pics????
  7. well... i have known the guy with the 65- FL for about 5 years. And even after he upgraded to a newer monty, the man regrets moving away from the landy. And this is not somebody who doesn't know what sorta suspension his suv runs. He owns 2 spares shops to my knowledge and knows his cars inside out. So i would listen to his view a lit bit more than that of a guy who did not know the suspension setup his uncles suv had. Even when it under went a replacement. You did not know something simple like that about the RR but you slam all land rovers based on that one RR. I dont know exactly why LR went under as you say but i doubt it was solely reliability issues. So many brands all over are not doing well due to multitude of reasons. gas prices, main costs, competition from cheaper alternatives, recession etc I dont have the interest nor the time to checkout kawi forums but i'm guessing those links are related to a certain line up of bike within the kawi range and not the entire kawi range. Kawasaki does makes loads of other models...including dual sport/offroad types. Honda CRF's...int their earlier versions had a lot of issues. Some engine went bust after mere couple of hours of hard riding. Busting a motor in one race was nothing new. But i don't think anybody said "hondas" were un reliable. They understood the fact that some of the CRF's were indeed unrelaiable and had issues. saying yamaha's loose power after "x" amount of miles. which is factually wrong...
  8. Dude... even the RR you talk about aint yours. so you really don't have true first hand experience. And based on one RR that had developed issues...you're slamming all LR that were made in the last decade. Also your comment on Kawis ticking and about yammies loosing loads of power after "x" amount of miles all are based on 1 specimen... by your own admission, the kawi wasn't looked after properly. basically you have had bad experiences with 3 individual vehicles and based on those 3 you're slamming all yamahas, all kawasakis and all landrovers. don't you think that's quite childish? Or in my view, quite retarded.
  9. as long as you get your soundstage right... being different brands doesn't really matter. If you wanna go all super pro and high end audiophile easiest is to get a singular system. If you know your stuff it's not too difficult to setup your own config. Loads of forums online with tons of info on how to do this, I'm taking a crash course myself to try and fix the soundstage in my truck complicated stuff though.... interesting but complicated stuff.
  10. maybe but it's very strange that a mechanically inclined chap like yourself, not knowing whether a vehicle you drive has air suspension or not. esepcially when that system failed and needed replacement.
  11. weird.... and here i thought RR sports came with air suspension or pneumatic suspension and not with hydraulics. In fact a cousin of mine still owns one in SL and that thing has air suspension.
  12. 1+ on Don...as always imho...it's pointless to spend that extra money on synth oil for such an old motor that was never designed to expect such fancy oils. A good mineral oil, changed at appropriate times with filter changes is all you need.
  13. just scribbled this on photoshop. keep the fuse as closely as possible to the battery. fuse value should be... add up the total wattage of the two fog lights and divide by 12... that will give you the amperage the circuit needs to run properly. say if total wattage is 200w.... 200/12=16.67 so a 20A fuse is what's required As for the relay, i would buy a used jap relay from a breaker joint... a denso one off a toyota is what i'm running. Also buy a relay socket/holder so things are neat. I bought some heavy gauge wire meant for household wiring made by ACL i think. The switch in the cabin...if the car doesn't have a stock fog light swtich that's already hardwired...make sure that switch power comes off ACC power. Or else if it's directly wired off the battery, you'll have to remember to switch them off eachtime cos they wont go off after you take the car keys out. Unless of course the switch is off.
  14. unfortunately double cabs are not very audio friendly. on my car i had 6x9's at the back, alpine type r's.. clarions on the doors and tweets on the a pillars... worked pretty darn well for me untill i sold the car. on the truck i have a bit of space behind the back bench seat for an amp/cap and only space for subs are under the front seats. Dont like active subs so only alternative is shallow mount subs. good ones from JL audio etc cost big $$$. So i'm still looking for a solution. Got about 4-5 inches under the seat for a sealed box...worse case scanario i can lift the seats off the floor about an inch or two... maybe two 8 inch or 6.5 inch subs from a good brand under the front two seats and the amp to be hooked behind the back seat...mids and tweets on the a pillars in addition to 6.5's on all four doors... plans plans
  15. maybe your friend had only seen on heard of that system. There are plenty non mainstream brands too that give great quality at a premium. really depends on your budget imho. Wont it be best that you decide how much you wanna spend on this and then look around for something that fits that? High end audio systems form a very large set of models and brands... your query is too wide to give an accurate answer. for example we got a bose system in our office that performs really great. Another friend of mine use a harmonkardon system etc... All depend on what you want and how much you're willing to spend
  16. No house/trance fans here? downloaded beatport 150 now only if i can get some decent bass in my truck
  17. exactly... some of the bad raps some cars are getting are truly unjustified. but on a good note...if you know your stuff picking up a used euro in a good condition is a great value for money deal while the rest of the herd follows mainstream stuff And i think it's retarded to bash and entire LR lineup manufactured in the last decade or so
  18. well MG have a mean arse kawasaki...ticking one too so quite possibly he attends bike meets too...
  19. kleenpark! recently a friend did some paintwork at autoforce and they too matched colors perfectly. but in both cases, the colors were not faded on cars and it was a stock color coded color.
  20. i know of a chap who had a FL for quite a while. 65- diesel. His only complaint was that parts being pretty darn pricey. He mentioned that once he had to replace the windshield and rear view mirrors and both those were very expensive compared to jap brands in the same segment. He own a spares shop so knows about cars. Reliability hadn't been a problem for him Eventually the man flogged the FL and went for a monty! And according to him handling and comfort of the new monty falls far lower than his old FL. Possibly Devinda or any other LR fan can shed more light on this. Also freelanders were dicussed before on AL if i'm not wrong.
  21. that's not entirely accurate mate. I had a metallic silver car sometime ago and have done a few touch ups. If you have coded paint color, it's just a matter of using the same code to paint it over. Only hitch is if you have custom colors or the pain has faded then getting an accurate match completely depends on the skill of the paint mixer
  22. awesome riding by him judging by how he closed up and overtook everybody by taking the corners faster and braking later thanks for sharing.
  23. Congratz to Darin then suppose he sorted out the tech glitches in his car
  24. if he is paying for it...you'd have to open wide and take it if not...i would do what i want! compromising is, at times taken as a weakness 5years and counting and i've never budged an inch
  25. ha ha ha...then you'd better get what he wants
