rangerover
Everything posted by rangerover
  1. Thanks for the info machang The body does have slight surface rust. It is the floorboard that needs work. Also the locks and internals have corroded. Will take a few more pics later on and update the thread. Hoping to start work sometime after the 18th of Oct. Just sorting out garages and parts at the moment.
  2. Thank you all for the contacts and words of encouragement! @Komisiripala I'm planning on starting work on this some where in November machang. Just trying to get the budget, garages and parts sourced within the next month or so as I want the project to flow without any hindrance once it starts. Will give your garage guy a call sometime this weeks as well I will drop in at Deens this friday or Sat and talk to them about the interior and get a quote. Will revert then.
  3. Thanks Guys. @Komisiripala I was actually considering Deens for the reupholstering. Will go this weekend and check with them if they can also do the spring replacements etc as well. Also, I reside in Borella. So i guess a tinkering place closer to borella would be the most suitable (I don't mind regularly travelling a bit further, if the quality of work is superior)
  4. Hi Guys I'm about to start a restoration project for a 1955 Peugeot 203 that was in my family for almost 60 years (one owner / one driver). The car unfortunately has been idle for over 15 years (ever since my grand father passed away). It starts and moves, but has several rust and other niggles to fix. My aim is to achieve near perfection (almost concours 'd elegance) with this project. Could you guys please advise me on the following, as this is my first ever restoration 1. Recommended place for tinkering (someone with very good experience in working with classics) 2. Complete repair of the interior seating, cushions (including the springs etc), roof lining and door panels 3. Restoration of body trims (should these be replated?) Im looking to get the silver trims and body fittings restored (also need to get the door locks, handles etc tinkered and restored) 4. A complete mechanical inspection and overhaul (a mechanic with experience in working with 203's or peugeot's of similar vintage) 5. A complete paint (I really need the perfect finish) job of the exterior and interior Appreciate some guidance on the above and on any additional areas I should look at. I have shown the image of the car below Uploaded with ImageShack.us
  5. Oil starts to leak from the valve seals. My previous E90 320i had to go through a semi engine overhaul at 40,000 KM. But that was an extreme case. But the N42 engine has an inherent problem with oil leaks. I would always recommend a prefacelift e46 for a petrol and a facelift e46 for a diesel
  6. So i am assuming your dad bought a 2006 1.8 liter. Because between 2007 - 08 the civic 1.8 liters mostly came fully loaded with a sun roof, paddle shifts, cruise control etc etc
  7. Have they run out their quota? that's pretty strange, given the poor performance of the FB series civic in this country since the launch
  8. Thanks Guys! value the input given
  9. Thanks Don. I guess if i am going for a matt finish paint, I will have to do all four pieces..
  10. Hi Guys The center door paneling of my Honda fd1 (the external black strip between the front and rear passenger windows) has peeled of (see picture attached). Any advise as to where and how i can get this done up? Thanks in advance RR
  11. Around the 7 mill. Which is too much in my opinion, given the price the B/N one is trading for. I would say 5.8 - 6.2 should be a good buy (as it is an absolute basic model) Slightly out of topic, how much would a good condition 2007 model E60 trade for? a 525 for example. Saw a few 2004 530i's going for around 5.4
  12. I would advise you to google "BMW 320D N47 engine" and read about the inherent problem these units have with the timing chains. It would be useful to know, especially in the event you decide to use it beyond the warranty period
  13. Guys, Any tips on where i can buy tools and supplies for model kit building? I have a few Tamiya, Aoshima and Fujimi kits im hoping to start work on. I can buy things like pliers, cutters etc on ebay for cheap.. but any idea if there are hobby shops or similar where i can buy the following; 1. Air brush kit (With compressor) - Single action 2. Model kit paint (Tamiya or similar) 3. And other model kit related tools Any help would be highly appreciated
  14. Never underestimate the saying; "if something is too good to be true, it probably is"
  15. Do any of these guys undertake euro gearbox rebuilds?
  16. rangerover replied to Rukster's topic in BMW
    Software issues are not limited to Euro's alone these days!
  17. rangerover replied to Rukster's topic in BMW
    Well these models tend to have a weakness in their DTC pressure regulator. If that is the case, the agents would opt to replace the entire pump, which would cost an arm and a leg. There is however a repair kit released by BMW for this issue. My E90 also had a similar DTC, Tyre pressure sensor etc warnings popping out at one point. It happened to be the steering angle sensor. Since mine was under warranty, they replaced it with a new unit, if not the first line of defense would be to clean the IR sensor of the unit. So basically, combined warnings could suggest various different issues, but you would be surprised how sometimes all it needs is a software reset/upgrade
  18. rangerover replied to Rukster's topic in BMW
    Can't clearly see the warning signs. I would just go for a resetting / upgrading of the software to start off with . Most of the initial probs i had with my car were sorted out with a simple software upgrade. But i guess, the easiest way would be to get it done at the agents. How much is the registration charge by the way? Didn't know they pulled of a D*MO
  19. rangerover replied to Rachitha's topic in BMW
    I have a 2006 n46, don't worry too much about forums. Just make sure you get your chain, guides and tension-er checked at the agents if you really want to. Believe me, owning a bimmer would be a nightmare if you engross your self in forums!!! just enjoy the car
  20. I personally believe that these EA numbers ruin the character of these cars. Saw a few W140's with these numbers, which looked quite gaudy IMHO
  21. Had a 2003 121 couple of years ago, got only 9.5 kmpl in the city. A 2004 allion i have at home also does less than 10 in the city. I'm talkiing central colombo travelling during weekdays!! So i don't think you are way off, if your travelling is limited to central colombo. Not sure about the outstation rate though. I guess you can try the following just to be sure; 1. Change air filter, petrol filter 2. Clean throttle body and do a tune up with a spark plug change 3. Make sure you are running the standard rim size 4. Ensure you pump sufficient air in to the tyres
  22. I guess. Seen him driving it around couple of months back
  23. rangerover replied to Eurofan's topic in BMW
    Land line - 2913465 Mobile - 0777389990
  24. Best is wait for a couple of years to buy these off the second hand market. Many permit cars are hardly used by their owners within the first couple of years. So better be safe than sorry!
  25. A nice 206 should do the trick. Just avoid the automatics if possible, if you do get an automatic, change the ATF
