Uditha88
Everything posted by Uditha88
  1. Uditha88
    Rpm Values
    Any help guys?
  2. Or use compress air in way that it really removes dust particles. replacing might be always good that cleaning/re-use. Also air filter life should not be measured against no of miles it did, but also based on the condition of the roads ur travelling.
  3. European plates due to import from there.
  4. Either Fuel related OR Battery current issue OR heat sensor issue.
  5. Uditha88
    Rpm Values
    Friends, Tell me RPM values of GA15 Engine(B14)or N16,FB15, 1 500cc, Automatic Trans. when all accessories off (AC too) 1. Idle in "N" 2. Idle in "D" 3. Moving in "D" about 25 km/h when no gas paddle pressed.
  6. Friends, Had an issue that car engine stall when in idle (N & P) Mechanic cleaned IACV (Idle Air Control Valve) & issue went away out. But it occured once recently again. What would be the issue? Extra Info: 1. Pumped fuel in the morning on that day that bad fuel case fired. (from La***s) But travelled about 300 Km witout any issue. (But i think if it's due to bad fuel, car should fail even when moving) Expecting experts views. Thanks.
  7. Friends, In new registrations, number plates are issued by government. I'm talking about old plates that individual people got made by them self. Is their any regulation in colors & sizes. I mean, front one should be "white & black" back should be "Yellow & Black" Is it a must? Some have black-white in back & in some car modifications, they use various colors. Is their any law?
  8. Better consumption. bad Economy I heard it's between 9-10.
  9. Agree. But it would be good if manage to get Good Condition "VTech" one. @KFL: And also we have to think that why such old EG8 & R10 etc. still cost the same as Rio what you refer as comparatively new... Also try Mazda Butterfly (just a clue)
  10. Extend ur budget to Presea R10 OR try Mazda Famila 323 old model || Honda Grand Civic
  11. Idle on N = 700 When D about 600 When AC on, again about 600. Means due to the load on engine, RPM goes down.
  12. Fuel Filter costs Rs 85 000 Something wrong somewhere. R u sure? The best fuel filter is VIC & costs about Rs 2 200/= (I buy & change fuel Filter on my Nissan MySelf) Why you wanna check up suspension? What you mean by "etc." What else you want to get checked? Suspension issues can be found by test drive by a Mechanic. Any good mechanic will find the issues. Can't directly direct u a place. But search & find a good mechanic & a shop. If so many matters to get checked & u lot bother about the quality try places like "L*L Ala****A"
  13. Most the things same as "Mazda Familia 323", as far as I know..
  14. Small Advice. It's good Short-and-Sweet But make sure some words give some other meanings
  15. Uditha88
    Cefiro A33
    Auto-power switch= Most probably it should be the switch to power on/off the transmission leaver, so that it might not be able to change accidently. Overdrive Button= It is used to off/on the the highest gear of the transmission. Eg. If 4 gear automatic, if you off the OD, transmission will not get into the 4th gear. Can be used in city driving condition where 4th gear seems not possible or when going downhill. Reasons: Will reduce the stress on transmission as no very large 3 to 4, 4 to 3 changes.
  16. What About; AUTOLANKA -> HYBRID Automotive OR OTHER -> HYBRID
  17. Others: Toyota Corsa/ Soluna, Nissan Presea, Mazda Familia Milage Would be(Roughly): Between 140000 - 200000 (But it varies)
  18. I filled Full tank when even 1 pump was closed. But I was lucky. Most probably solution for you will be replacing fuel pump. Take her to a mechanic. What to do...
  19. Uditha88
    Nissan Cefiro
    7-8 Km/L in City
  20. The place which generates noise must be properly identified. You might get help from a 2nd person or take the car to a good mechanic. After a test drive, experienced mechanic can understand the issue by noise. Additional: There are some gadgets even for sound recognition for vehicle diagnosis. Don't know whether those are used here. It's all Mechanic's experience.
  21. Uditha88
    Breakpads
    Also get checked for Break Bindings...
  22. Either Dumi*** (body***.lk)or Asnka Ganepola (Macvud)
  23. Ya. Parts rare & expensive. But durable, powerful make.
