PHEV conversion
lol I remember seeing something about an Australian company that in fact build PHEV kits for the Prius. Not sure if they are still operational, but the thing I remember mostly was that the ranges they give were not that great.
Eco mode How does work?
Varies from vehicle to vehicle, but the common mechanisms are: 1. Change shift points (automatic transmission): The transmission shifts gears sooner to keep engine RPM minimal. Low revolutions means less combustion. Less combustion means less fuel consumed. This is the most commonly used method. 2. Optimise throttle responsiveness: The ECU changes the way it reacts to the readings from the throttle position sensor. This means the accelerator pedal will behave slightly different than in normal mode. All done to minimise the use of fuel. 3. Lower idle RPM: The ECU lowers the engine RPM when idle to burn less fuel. 4. AC operated efficiently (Automatic or Climate Control AC): Automatic AC works differently to minimise load on the engine and thereby save fuel.
Attaching a USB charger on Factory Blank switch on Corolla 121
A USB port's voltage on a PC is 5V and the amperage is 500mA or 900mA (USB 2.0 and USB 3.0 respectively). If the phone can be safely charged by plugging it into a PC, then surely it can be charged through any USB port that outputs 5V and amperage between 500mA and 900mA. Having said that, some phone chargers supplied originally with phones nowadays have ratings higher than 900mA. My phone's charger for example says 5V 2A. Charging it plugged into a PC takes quite a long time. I think most people ruin (by ruin I mean shorten the lifetime of the battery) their phones with car USB ports and adaptors is because they used a USB adaptor with a higher charge rate than the battery should be charged at. When buying a charger, it is important to check if the charger or adaptor is suitable for the devices you plan to plug into it. I have a Belkin USB adaptor that plugs into the cigarette lighter of my car and the rating of that is 5V 600mA or something. So almost any phone can be safely charged. I could have gone all the way up to 2A, but my wife's phone came with a charger with a 750mA rating I think. The eBay link that OP has shared says that the ports output 5V 1.2A/2.1A. So if you charge a phone that is meant to be charged with a 5V 500mA power source for example, obviously the lifetime of the battery will suffer. My 2 cents.
- Attaching a USB charger on Factory Blank switch on Corolla 121
The cigarette lighter is not that far away. But if the fuse box of the 121 is closer (above the pedals maybe), you can locate the fuse that powers the cigarette lighter and tap into it. You can get a compatible fuse tap from eBay and do a clean job without cutting any wires. Just an alternative suggestion to Rumesh88's.
chevrolet cruze ABS modulator
Glad you managed to sort out the issue. Would have been a far more expensive (and pointless) repair if you blindly followed your mechanic's advise and replaced the ABS module.
- fuel consumption of honda civic hybrid
What is Best vehicle with the Best resale value ?
Welcome to Sri Lanka.
Brake Booster
Dear Nalakasm, please stop opening threads for every issue that pops up into your mind about your car. We understand that you want to get all of them fixed, but opening 4 different threads during a 5 day period is not the way to go. 1. Search the forum. See if you can find the answer to your problem. If you find a thread that is closely related to your issue, respond to that thread instead of opening a new one. 2. Use 1 thread to ask all issues you come up with your car. Call it "Help with my Nissan HB11" Opening multiple redundant threads makes it very difficult for people to find information on the forum amidst the vast amount of threads that are already here. As for your brake booster problem, you will have to search in Panchikawatte for a used one. If you fail, you can use an adaptor plate and use a booster of a different vehicle (preferably a Nissan).
The errors say that all four of your wheel speed sensors are at fault. The first thing to do is to check if all wheel speed sensors are clean and if the sensor rings are okay (no damaged teeth, not filled with dust or dirt). Clean them if necessary. Since it's unlikely for all four sensors to fail at once, it might be a connection issue on the wire harness that goes into the ABS module, or the ABS module itself being faulty. Check to make sure that the connections are secure.
Fog Light
@trinity did this on his CS1. More info in the thread below.
Music To Drive By
Added a couple of these to my playlist. Thanks PL!
Was it confirmed that there are no vacuum leaks and that your booster is properly working before it was determined the problem was in the ABS module?
Reverse Gear
Welcome to the forum! Is this a recent development or has it been this way all along? Not sure about the HB11, but some older cars required the gear lever to be pushed down towards the floor before shifting into reverse. This is done to prevent accidentally engaging reverse gear while the car is moving forward. Drivers who don't know this often struggle trying to put the gear into reverse. Make sure this is not the case in your car. Members who have experience with HB11s should be able to comment. If there is actually an issue, it could be due to worn out linkages and bushes. The linkages (starting at the foot of the gear lever) should be inspected to determine if friction or an obstruction is causing the difficulty. If your transmission fluid has not been changed in a while, you might want to check the condition and level of the oil as well. I have come across difficulties in engaging certain gears which was due to bad oil in the gearbox.
Music To Drive By
I have been following this thread closely, but I never got the chance to respond. I have a soft spot for music from the 80s and 90s. Back when music was simple, yet most songs had a meaning that made the hairs on the back of your necks stand up when you listen to them. Call me old, but only a few modern songs makes me feel that way. As a kid, I remember listening to UB40, Jimmy Cliff, Bob Marley, Bee Gees, Boney M, ABBA etc. a lot while riding on the back seat of my father's 4 Sri Volkswagen Beetle. Whenever I hear a song like Kingston Town, it takes me back to moments in the past. Being overseas and away from home, the nostalgia is overwhelming sometimes. So for me, there is no great feeling like taking the car out for a spin while listening to some good old 80s music. I've been filtering out 80s songs for a couple of weeks now and building a Spotify playlist with my favourites. This is what I have so far. I plug my phone into the car, turn up the volume and drive to these tunes. I often catch myself taking a longer route to the destination, just because I want to listen to that next song! Let me know if you guys can think of anything else that I can add to this list. Ones that are not too slow to make you fall asleep on the wheel. I'll share my other car playlists when time permits.
- Viva Ellite fuel consumption
Engine misfire of FB 14
According to my memory, it has a distributor with a single coil inside the distributor housing. @Liyo, Welcome to the forum! It can be due to the coil, but there are other possibilities as well. Can this be experienced always or just when the engine is warm? When the issue comes up, you can get a mechanic to check if each plug gets a spark from the distributor.
Ignition Coils Burning Frequently
Oh right. I was a bit confused about the ignition coils for a minute there. If there is a gasket leak, there is a very slim chance for coolant residue to be deposited over the spark plug electrode that in turn cause their resistance to become higher and thereby causing the corresponding coil to overwork, heat-up and fail prematurely. This again is thinking out loud while being a bit paranoid. But anyway, have you checked your spark plugs? Did you change them and maybe the new ones are of higher resistance? I think you have a few things to check now for issue #1: - Ground connections - Alternator and charging (idle, load etc.) - Condition of spark plugs (this might give you an indication of a gasket leak, but not if the leak is very small) As for the coolant level drop, check the heater element inside the car and the lines + what others have suggested above. If it's a gasket leak, there's no way to find out without taking the valve body out. I have one of these to diagnose issues without taking stuff apart. Can take the 4 plugs out and insert the camera through the plug hole and look around for trails of coolant + corrosion. I wonder if any local garage has a industrial version of this type of "endoscope".
Transmission issue in Lancer CK2
In the layout diagram of the engine fuse box, locate the relay that is against a symbol that says "A/T" and get that relay checked. It shouldn't be too expensive to replace, so I'd get it replaced anyway if I were you. This I believe is the first point of diagnosis.
The Cerato has a bottle type ignition coil? I find that hard to believe. Pretty sure it has a regular "coil over plug" set up where each coil powers either 1 or 2 cylinders. I'm gonna assume this is the case and base my response on this assumption. 1. The coils are supplied power through the ECU by determining many engine parameters including the crank position sensor. If the ECU supplies more power than the rating of the coil, it will eventually burn out. So it could be that your replacement coils are simply wrong (were they used?) or your ECU might be at fault. Just my 2 cents. Having said that, first you need to make sure that none of your engine's ground connections are bad. Especially the ground connection from the battery and the one(s) connecting the engine to the car's chassis. Also, make sure you get the alternator and charging system checked to make sure that the battery is not being overcharged. 2. Might be a very small leak where the coolant evaporates before it even hits the ground. Hope you thoroughly inspected the engine compartment (water lines) for coolant trails or smudge marks. The bright colour of the coolant should allow you to spot it fairly easily. The leak might be in the AC heater element as well. Didn't you have a brake issue with the Cerato a couple of months back? 3. You can do a simple test to determine if the booster is operational: Hope this helps.
- Post Whoring - Part 2
How to improve the breaking distance - L200
1. Get your brake rotors and drums resurfaced With time, the surface of rotors and drums become smooth and shiny, causing the frictional properties of the surface to lower. You can get them resurfaced (commonly referred to as "facing" in SL) which will give the surface the proper texture as well as get rid of warps and heat spots. 2. Use good brake pads The use of cheap aftermarket brake pads might be the reason for the car "dragging" even under heavy braking. I was once surprised when I changed a set of aftermarket brake pads to genuine ones, noticing how much more efficient they were. Not saying only buy genuine pads and liners, but stick to a good brand. Looking at the photos of your tyres, the tyre in the top photo seems to be too far gone.
GEARBOX OIL LEAK.
Looks like it's the pan gasket that's leaking. A pretty straight forward fix. Take your car to a mechanic and get the gasket replaced. If the car doesn't come with a gasket, the mechanic will apply a thin layer of gasket maker and install the pan. In any case, your transmission oil will have to be drained out first. Make use of the opportunity to have the condition of the oil checked and do an oil change if required.
I'm not sure about Piduruthalagala, or the performance of the Alto in high altitudes (Who knows, "Alto" means "Up" in Italian, so maybe it just an indication of not to take it "Up" :P), but this gentleman is right about cars in general not being able to perform well at extremely high altitudes. I believe modern ECUs can deal with this to a certain extent though. The Oxygen density is far less at 2500 meters above sea level. An ICE needs sufficient Oxygen to perform normally, There was a Top Gear episode in which the trio was climbing a whopping 17,000 feet or something (twice as high as Piduruthalagala) and the engines were struggling to keep up + the presenters were struggling to breathe. Will try to find the clip on YouTube and post it here.
- Both ABS Warning and Hand brake warning indicators on
