Everything posted by Clark's son
Diesel Car Around 1.7-1.8 Million
IMO if there are no electronic issues or transmission issues you are ok. Other mechanical, cosmetic and trim related issues wouldn't affect much and you would be able to fix it when you'r bank is ok As most D9 HDi s came with a manual box so transmission issues will be minimum. Find out if there is an independent specialist for these because well .... the agent is C*rm*rt . If you find one take it to him and ask the cost taken to bring it to good condition and consider that when giving an offer. And also don't stretch you'r budget too much going for the thing you want after all it's a euro
Allion
According to my knowledge 260s are mainly seen in unreg. conditions the ZRT(A18) is a little bit more expensive(lower cif but higher taxes). But don't know what will happen in the future. BTW I would recommend that the FD1 or Lancer EX will be better than these allions that are everywhere.
- Post Whoring - Part 2
Whichever car you choose you should remember that they are almost 15years old so you should spare some cash for repairs just as you buy it. If you could try to snatch a VW or Audi A4 Tdi at that price you are lucky, and sometimes with a dedicated search and bargaining it may be possible. From what's in you'r list the 406 ticks all the boxes except one which is the decent looks, to me it has exceptional looks for that price range
Allion
If the prices are same go for a face lift For 3.7mill you can easily get one. But if the prices are ridiculously high go for pre face lift. Just some cosmetic mods that you can fix from punchi, and a slight change in the meters that's all. I would suggest to go for the 1.8 zzt240 model as the 1.5 will be underpowered and will cost more fuel in highway and hill country driving. And from a luxel experience the 1,8 does better than the 1.5 Also as sri lankan morons who overprice underpowered vehicles you can snatch a good 1.8 for a pretty lower price, below 3mill for a good 1.8 if you bargain enough. Don't go for anything above the 4mill mark because you could be reaching for the nzt260 price range. Ps- A new model will be released in 2013 so prices may drop(if you are considering resale value in choosing an allion)
Shock Absobers
And also there will be a reduction of handling capabilities wouldn't it. About 10yrs ago when we went to unimo to replace the shocks of our CB8, a friend who worked there told us to use KYB as they are completely same as the originals. That saved us some bucks, no complains. Some time later we replaced our AE110s shocks with KYBs but the ride comfort got awful, may be been used to the worn out shocks may be a reason. But just find out which is the OEM and better use it
Nzt 260 Display Meter
Deleted as I don't want to feed the troll
Suzuki Liana 2002 High Rpm At Idle....
IMO The scanner only checks if a sensor has completely failed, In the process of failing or due to been interrupted by deposits it may not function as intended, For example a defective map sensor might run the engine rich and cause high idle speeds. These are cleaned in a full fuel system clean up so you should go for one. Would take couple of hours but i recommend you to observe the work been done as they could skip some parts. From what i know with AC the RPM should increase but in you'r case it decreases this could be due to a defective so called AC clutch. BTW is this the Singapore model Is this with the completely digital meter
Help To Buy A Car For A New Driver
Yep, Don't buy something thinking you'd wreck it, Buy some thing you like It some times develop a great sentimental value as the first car you used. And as you'r an armature it is better to go with a small hatch back that's easy to drive. My personal experience learned to drive in a nissan march pretty easy to drive. A nissan march, suzuki swift ect. are good vehicles for you'r requirement. If you'r really not confident try to get a second hand one for a cheaper price. If you are not much confident with the traffic and the hills go for a auto, but try to shift to a stick-shift when you get experienced, It's pathetic how some people don't like to use the stick shift now, if you get too much used to the auto this would happen
Keyless Entry Key
Same thing happened to one of my friends, But because he knew from the number he went to a watch shop when he changed the battery of the spare. This comes to show how much agents rip you off. But the company says it is specially made for the car @OP Try to keep the remote near the push button and start it up if it refuses to start as the don said and use the mechanical key to open it if it doesn't open. May be if the spare was not used for a long time it's battery must have also gone flat. Try replacing the battery, Remotes where advertised around Rs.40 000.00 at Adv*nc*, so if the battery thing doesn't work take the remote to them, they will try to repair it if it doesn't work you'll have to buy a remote and programme it. I once inquired about any faults about the system inside the car from the company and they told that there where not reported yet but the unit would cost Rs.500000.00 if replacement was needed.
Go dig the ground looking for treasure than, digging out topics over one year old without a reason. FYI - Unfortunately Sir isaac newton had found out that things rolling down does not consume energy some time ago with an apple before you and KMG found it in you'r allions. And you wan't be able to get the noble prize for that. So go dig a hole and plant a tree, That would be more useful for the world than polluting cyber-space with you'r retarded ideas
How To Find And Fix Leaks In Your Tubeless Tires
They might be wearing some brand of shirts thinking the ladies will change the tiers for them Seriously, dropping by a tier shop How hard can that be?
Honda Hrv Owners
IMO it is better to source a secondhand vehicle from a genuine user than a buying and selling business man, due to the below reasons, 1. They must have bought the vehicle for a less amount fro the previous owner meaning that you could have got it for a cheaper price. 2. The businessman will always try to make a profit by hiding problems and doing temporary fixes, so that the problems persist, 3. They know a lot about how to hide problems because than the owner because it is their job. 4. They are experienced in ODO meter adjustments. 5.And sometimes owners sell their vehicles to these because they can't face the customer(due to the vehicle been a lemon), - I have faced this problem once and finally sold it to the same sale for 20% less (as i also didn't want to face the buyer) due to the vehicle been completely destroyed by overheating. So go to the buy section in autolanka select Honda type HR-V, and find a vehicle which suits you. If that's not enough get some Sunday papers and go trough the classifieds. Yes if you really like the car take it for a extensive check-up at some place you know, because problems may be hidden. This is just an advice. There may be completely genuine car selling businessman
Obdii Compliance
Does those OBD to USB cables advertised in e-bay really work and can we program the ECU using the software available Does anyone have any personal experience.
Car Mart No Longer Mazda Agents In Sri Lanka ?
IMO as i have said before, as it says c*l*nial motors is an importer and distributor of the Mazda Motor Corporation, not the sole importer and distributor, It seems that C*rm*rt can still keep their business going. This is just regarding the interpretation of the sentences said here, I don't have any info about what is really going on.
Ever Heard Bio-Diesel?
Great job kid, You'r invention will keep the cars running even after the crude oil resources have dried up. And please do post some pictures of you'r experiments. Including the vehicle numbers you are testing on, So that the good people here in autolanka could refrain from buying these vehicles with ruined engines someday.
Rpm Limiter - In Toyota Vehicles?
And to think the RPM limiter is the thing to be most concern about when buying a car, Well if the vehicle didn't have a defect the gas wouldn't jam open and the engine wouldn't blow. And even if the driver was aware he would have turned off the engine, what if this happened on drive some one could get killed.
Formula 1 - 2012
Nice to see how the repair work was done at the Audi garages and they set some almost retirements back into the track, And the way that the drivers didn't give up, Even Dumans was also saved by the crew. Wait till our own CALI hears about the E-tron victory. At least they haven't used an ugly hybrid badge on it like toyota had done.
Formula 1 - 2012
That bugger is coming to Le Mans
Rev Limiter Question
According to what I know Petrols reach there Rev limiter at 6000rpm, and diesels at 4000rpm. As I think that you aborted the convertion it must be petrol. Tryed to do a Burnout in the auto Ay..
As the word sole importer or distributor is not used, I think that C*rm*rt will be able to Mazdas too. After all does anyone who use VWs go there as long as Senok and the guy near that cement plant are around Fianly can recomend a Mazda to somebody.
