June 22, 201214 yr wind only retain for 4 days in one of my tire... how to fix this..do I need to replace my tire? will tire house fix my issue..how thy will fix?
June 22, 201214 yr either you have tyre puncture or tyre doesn't get sealed properly to the wheel (provided valve doesn't have any problem). Didn't you take it to repair still or what did they say?
June 22, 201214 yr Are you freaking kidding me? You need to post a flat tyre question here??? If you dont know how to handle a deflating tyre you should not be a car owner.
June 22, 201214 yr wind only retain for 4 days in one of my tire... how to fix this..do I need to replace my tire? will tire house fix my issue..how thy will fix? by the way you call it "air" not "wind"
June 22, 201214 yr I'm with watchman on this. I mean, really?? What's next? Car won't start. Do I need to put that yellow liquid at the pump? Is it really necessary?? You're trolling for a problem that will cost you 100 bucks to fix at the tyre kadey
June 22, 201214 yr I'm going to assume that the OP has never heard of leaks and punctures and "air" and explain a little bit. The time taken for your tire to deflate depends on the extent of the leak. The bigger the leak, the shorter the time taken for the tire to go flat. Your tire probably has a small puncture or a leak from the valve or the edge of the rim provided that the tyres are not worn out. That's why it takes 4 whole days. With me so far? What you need to do now is take your car to a tyre shop and tell them that the tyre deflates in a matter of days and ask them to check for leaks. There are tyre shops everywhere and Tyr3 H0us3 is not the only place that fixes tires. If you posted the question because you want to check for the leak yourself, do this: Mix some water with car wash and spray it all over the tire and look for air bubbles. Pay special attention to the valve and the edge of the rim. To do a good job, you might have to jack the car or take the wheel off. Replace your tire... seriously? that's like replacing the engine because you ran out of gas.
June 22, 201214 yr Author I'm going to assume that the OP has never heard of leaks and punctures and "air" and explain a little bit. The time taken for your tire to deflate depends on the extent of the leak. The bigger the leak, the shorter the time taken for the tire to go flat. Your tire probably has a small puncture or a leak from the valve or the edge of the rim provided that the tyres are not worn out. That's why it takes 4 whole days. With me so far? What you need to do now is take your car to a tyre shop and tell them that the tyre deflates in a matter of days and ask them to check for leaks. There are tyre shops everywhere and Tyr3 H0us3 is not the only place that fixes tires. If you posted the question because you want to check for the leak yourself, do this: Mix some water with car wash and spray it all over the tire and look for air bubbles. Pay special attention to the valve and the edge of the rim. To do a good job, you might have to jack the car or take the wheel off. Replace your tire... seriously? that's like replacing the engine because you ran out of gas. Helped alot thanks mate!
June 22, 201214 yr See this is the reason 95% of Sri Lankans should not be driving. If you don't know what to do when you have a flat tire you should kill yourself now or start wearing panties and a skirt.
June 22, 201214 yr I'm asking this becuase I haven't seen doing this, How do the tire kade guys secure the tire to the rim, do they apply a special glue or something ?
June 22, 201214 yr I'm asking this becuase I haven't seen doing this, How do the tire kade guys secure the tire to the rim, do they apply a special glue or something ? Yes, there is a sealant that should ideally be applied on both the rim and the tire bead (it's a black tar - like sealant). The most common method of application is using a brush. I've however seen tires being mounted without the sealant as well. I guess it's most useful if the rim has a rough or corroded edge.
June 22, 201214 yr I'm asking this becuase I haven't seen doing this, How do the tire kade guys secure the tire to the rim, do they apply a special glue or something ? They do apply a liquid along the edges of the tyre. if i'm not mistaken the general idea is that tyre by design is a tight fit to the rim. And when you pump air into it the pressure kinda locks the tyre further to the rim. I'm sure you have some freetime at hand.. why dont you goto a tyre shop and see how its done... wont take even 20 mins... Edited June 22, 201214 yr by Watchman
June 22, 201214 yr See this is the reason 95% of Sri Lankans should not be driving. If you don't know what to do when you have a flat tire you should kill yourself now or start wearing panties and a skirt. They might be wearing some brand of shirts thinking the ladies will change the tiers for them Seriously, dropping by a tier shop How hard can that be? Edited June 22, 201214 yr by Clark's son
June 22, 201214 yr See this is the reason 95% of Sri Lankans should not be driving. If you don't know what to do when you have a flat tire you should kill yourself now or start wearing panties and a skirt. agree with this totally i think there are some who wear panties and skirts but still aware of what to do during a basis problem like this
June 22, 201214 yr See this is the reason 95% of Sri Lankans should not be driving. If you don't know what to do when you have a flat tire you should kill yourself now or start wearing panties and a skirt. Was waiting for JD to show up with troll-nir and hammer some sense into this!
June 22, 201214 yr This s the dumbest thread in a long time!!! I beg to differ, unless long time is last week
June 22, 201214 yr I beg to differ, unless long time is last week Didn't jami create a new thread a couple of days ago?
June 22, 201214 yr Didn't jami create a new thread a couple of days ago? Ah yes the one comparing Nissan March K10 and the Maruti K10 engine
June 22, 201214 yr When you read the comments and the questions of some of these newbies and the not so newbies, you wonder how the hell hey exist... Some of them won't be able to find their own bung holes in the dark, EVEN when they are using both their hands... let alone a bloody puncture that is taking the 'wind' out of a tyre...
June 22, 201214 yr When you read the comments and the questions of some of these newbies and the not so newbies, you wonder how the hell hey exist... Some of them won't be able to find their own bung holes in the dark, EVEN when they are using both their hands... let alone a bloody puncture that is taking the 'wind' out of a tyre... Lets just hope they will never procreate.
June 23, 201214 yr Lets just hope they will never procreate. Amen to that! Opening this thread assuming it's a DIY guide and reading the OP's question was ... well no-words-for-this moment!
