Everything posted by kelum_wj
Ek3 Head Light Projection Conversion Advice.
Yah. try Motorcade if you want Hella Micro DE. And try motor accessory shops in darley road
Lancer @ 100Kmph
Did you do wheel alignment after changing the rack ends? Did you fix new alloys? If you haven't done wheel alignment after replacing rack ends, get it done. And if you fixed alloys get the wheels balanced. Also it might be a tire with broken belts
Try Projector fog lamps with HIDs. They would be cheaper and will aid the low beam . Eg- Hella Micro DE
Don't Fix New Modified Valve Covers(Cap) To The Tyres
These come with a wrench key chain. These can be locked using the wrench. http://www.brilliantstore.com/pimagesl/l_os-ec1345-3.jpg
Need Help For 1997 Civic Ek3
I'll PM the contact no
04- Try innate graphics. Also I remember him having a Mesh grille for sale. 05- For a normal tune up he doesn't chip the ECU. Chipping is done to improve performance by using fuel and ignition maps and it cost a lot more than a normal tune up. . Normal tune up involves cleaning of injectors,throttle body etc as said by Mkx
This happened to me also. Now I use a set of lockable dust caps and no issues so far
- Ek3 Head Light - Bulb
Toyota Townace Head Lamp Issue
The cheaper ones have issues with ballast. Going for a good brand like Philips would be better.
New Fog Lights
Is it the whole kit including the wire harness, relay and switch or is it only the lights?
Help Me To Buy A Honda Civic
ES3- Comes with a D17A engine. Fabric interior and comes with bodykit , optional sunroof and 15" alloys. It does about 8-9 kmpl in the city.
A Star Vs Estilo
It depends on your requirements. The Estilo has more legroom,headroom and boot space and has a better driving position than the A star. The A star has better interior and handles better than the Estilo.
Maruti Steering Vibration
Well said bro. Maruti 800 has poor brakes. If somebody wants to drive at that speeds he should upgrade the brakes
I would advise you to take it to A*W @ Royal gardens.
The Maruti 800 comes with a steering damper .
Bro then You must have driven one with either misaligned wheels or bent rims. Did 100 kmph on parliment strech on a testdrive to check the alignment after aligning the wheels at the agents and didn't notice any vibrations. Don't assume things
This is due to the misalignment of wheels.Get your wheels aligned from a good place. If you've change the rims to Alloys get the wheels balanced too. Also if the rack ends wear off it will make the steering vibrate at speeds more than 60kmph. No this is not the nature of the car.
Virs Or Manual V-Tec
Yup. Then its a VTEC
Seems to be a good price bro.If u can make it 1.6m or less would be a good deal .Anyway make sure it's a Vi because I've come across people selling EXi version saying its Vi.
Micro Sedan Car
My advise is to stay away from it. One of my uncle's bought one and after 4 months the car started heating due to a faulty radiator fan. Also it does about 7 kmpl though it's a manual. It's better to go for a used Jap car
Honda Eg8 Lights
If its the stock headlamps its H4. If its Projector lights the High beam is H1 and Low beam is H7 if I remember right. Also I would advise you to go for 6000k as 8000k would be useless in bad weather .
200Cc Vs 240Cc Fuel Injectors
With the addition of injectors with a higher flow rate you'll decrease the fuel pressure. To overcome this you'll have to use a Fuel pressure regulator or a different fuel pump. Also as said by Ripper the ECU should be remapped and u'll need to use a high flow filter replacement filter or a Cone filter to provide sufficient air. Btw which car's injectors are you gonna use on it?
Grilles
How much did it cost? Btw I thought that it was for the Kelisa
Grilles
This looks sporty and the billet grille would look stately
- Grilles
