MV-5
Everything posted by MV-5
  1. No , my point is , any of those 3 sizes will not increase the ground clearance (those have roughly equal radius, only rim size is different).
  2. Yes, that is an option. but definitely there might be a good reason that manufacturer design this vehicle with this kind of ground clearance(probably from vehicle stability perspective). So my suggestion is that "use the right vehicle for the right purpose".
  3. 175*0.7 = 122.5mm = 4.82 inches 4.82 + (14/2) = 11.82 185/60/R15 = 11.87 195/50R/R16 = 11.83
  4. if the effect of 185/60/R15 is negligible for you, then 195/50R16 would be not effective. (7.5 + 4.37) is very close to (8 + 3.83)
  5. oh 500K USD???..... then "poniyek aragena conversion kit ekak gahamu".
  6. if you have the previous maintenance records(genuine), things should be done depends on that. if you don't, then assumption should be biased towards the worst case (Ex: if MT->then change Transmission oil, AT->, then ATF).
  7. http://www.car-parking-sensors.com/faq.php
  8. again, thumb rule is that "ODO reading is just a numerical value"
  9. that means no stock car has more than 93db? or we have import restriction???
  10. Do they have "sound level meter"? 93db within 1meter , 2 meter or 10 cm???
  11. Hi Kala, what do you mean by "single abs unit". is it the speed sensor?
  12. MV-5 replied to Komisiripala's topic in HONDA SRI LANKA
    <Quote> Posted 17 June 2013 - 06:18 PM i'm yet to hit 150. and i've had some very well maintained cars. -Komi in http://forum.autolanka.com/topic/15233-vibration-at-high-speeds/ </Quote> finally you did it
  13. MV-5 replied to MADZ's topic in The Lounge
    http://tdi-plc.com/blog/japan/mitsubishi-evo-8-fq400-development/mitsubishi-lancer-evo-8-fq400-upgrade
  14. it is not a random sample. it is called biased sample. reason is that you prefer shorter girls . try to pick a "real" random sample for your n-ex-t girl friends. anyway , don't worry, even though tires are worn ,if it is a "insight" it will not give any trouble,"even a punch in the tyre".
  15. Nothing is correct in my post. i was just kidding!. pls don't ask the "why".
  16. Of course! i didn't, i did add more flavors!
  17. 5' 2'' is not a magical number and it was calculated based on huge analysis done by Toyota. they have done a survey with more than 2 million persons and better sampling strategies. then they have identified that "Heights of people" can be represented by a "Normal distribution" and they have calculated the "Mean" and "standard deviation" for that particular distribution. based on that values they calculated the "Probability" that we can find a person who is not higher than 5' 2''. that value is 0.00985634. world population is 7 billion. total number of cars manufactured (prius family) = approx 4 million then probability of having a Prius for a given person = 4/7000 = 0.000571 since "not higher than 5' 2'' " and having a prius is mutually exclusive, the probability of having a Prius for a given person and that person is not higher than 5' 2'' = 0.009856 x 0.000571 = 0.000005632 this answer is closer to 0 that means Toyota will win the case.
  18. you are so precise , i googled and found that 5' 2'' = 157.48 cm (i didn't google about Prius ) FYI . thanks for so valuable information.
  19. no , this is 700
  20. in this case , best exit is "Kurundhugaha" , then from exit to Ambalangoda road is a road better and wider than Galle road.
  21. yes machan, then it is not applicable. I always try to jump to a conclusion based on problems i came across
  22. leak in clutch pump, or clutch pump washer related issue. in a flat road, try to use clutch frequently as you said (just press several times) and then change the gear to 1st. release all brakes, clutch pedal should be fully pressed. wait 1-2 mins, if your vehicle starts to move then probably above root cause is positive.
  23. MV-5 replied to MADZ's topic in The Lounge
    then owner has already saved 20,000 liters. if the average petrol price per liter is 100Rs over the period , then he has already saved 2 mil. Not bad , ha.
  24. Since the information that has been posted is correct ,This sort of thread (formatted closer to article) should not have led us to this kind of conversation. if first two lines describe kelums view on car modification, still MD or any member has right to question that and since this is a open forum ,kelum should reply that (still we are not in a position to guess kelums intention, MD might have interpreted it incorrectly). @Supra_natural what Trinity was trying to say is we could have given high priority to this "format", then we could have forgot about first two lines and Moderator involvement was needed. that means MD has right to ask the same question again and again in different ways, but other MDs post can be categorized as OT (my view). Kelums effort should be appreciated, and the question has been asked by MD should be answered.
