varunatech
Everything posted by varunatech
  1. just wanted to know the facts and thoughts behind your comment. I always know that others may know something that I do not know........your points may be correct and personally I feel Dr Kulasinghe memorial Express Way is a fitting name for an iconic Civili Engineering project of the country. http://www.kulasinghe.com/main.htm By the way I cannot agree with "Science fiction writers are a dime-a-dozen"............I have read many and Arthur C is a damn good one of them.
  2. AT working temp, the 1NZ-FE engine should idle at 600RPM. Most probably the engine in question here need a tuneup as basic. Might lead to other things as well. If it is a cold start, the engine might take more than 5mins to come up to the working temp.
  3. Hi Jdnet, no problems in having your view to yourself. But could you let know why you think Arthur C, is a not a worthy name or an individual.............
  4. Guys, both 121 and Alion 240 has higher kmpl figures (tested many times) in City traffic. Please verify the way you calculated and also look for tuning issues. A car sitting in one place for one year is a pretty nasty thing. Might need a good look at the engine and all fluids to be changed. A good tuneup is also mandatory. If you can explain more on the situation, will try to help as possible.
  5. It is also called "Balla"or Dog, as it drags behind always, faithfully and no questions asked 'like a dog". This simple piece of technology helps the cart in steep hills, so the Bullock can take time to relax and rev up to get to needed Bullock Power (not horse power)...... By the way I have heard that in Langama (C.T. driver training, they ask the drivers to park the Bus in a very steep climb, and the instructor place a matchbox behind the rear wheel adjacent to the wheel. And the driver is asked to pull forward without crushing the match box, means virtually he should have perfect clutch balance.........
  6. Yes manifold vacuum is used........I still thinking how the alternator failure of Watchman caused less braking power, unless he has a vacuum pump on the same drive belt and the belt failed. But usually only Diesels have vacuum pumps ........
  7. I did not want to go technical, the OP dude seems way out. I do not think he will care a jack shit about how servo brake works. Guy seems to enjoy his day coasting downhill forward and backward. I was rather worried he will break his neck or will break others too
  8. You lucky that you have not gone through an accident so far............and still you are in fear that this is a fault of your car and believe the break should work normal with your engine off. Read some basic info in web about car mechanics. Will help you. But "NEVER AGAIN DO THIS", also never ever let your car run free in Neutral, when you go down hill or as a smart idea to save some fuel. That is a very BAD idea as well. Hope this helps....................there is something called engine break.........and you need it when you go down hill. Read it from Google.
  9. DO NOT SWITCH OFF ENGINE AND TRY TO USE THE BREAKS. The engine is required to run your breaks, The engine provides the needed power to pressurize the brake oil and so on. I am not explaining in full, the technicality behind this. If you try to do the way you do now, either you will have an accident and while doing so will injure others and damage property to too.
  10. Hi Folks, I did want to change the Tyres and out of the lot decided on Bridgestone Turanza AR10. Went to the agent's web site, pretty neat and informational, specially on the dealers. Found that a reputed and known Dealer nearby has the AR10s. Ran a call to the local dealer, and he has the stuff. And I know the guy personally and not a cheat by any means, genuine and reputed. Also the guy is techi and know that I am on to the details as well. Went there happily and was waiting for the tyres to be fixed, while having a chat with the owner the tech guy. Just to be on safe side and I did check the date of manufacturing for the four tyres.......... Two in 2012 and two in 2009.............. I told the owner and he himself checked and apologized. He straight ran a call to the agents and blasted them for the two old ones and insisted immediate replacements. He kept on apologizing to myself, but he did not have to because I know very surely he is genuine. When unloading the lot knowingly or not,,,,,,,, two 2009s has crept in. I am not saying the agents did this willfully or they are cheats, but better to be safe and know the game. I hope everyone in AL or at least majority know how to check the date of manufacturing. If not please search or do a Google...........
  11. varunatech replied to SeanD's topic in General
    Always use them, trap dirt very effectively. 3M is expensive, but the look alike Arpico ones do the job too but with less durability
  12. Great work !!!
  13. Common car wash products strip off wax layer..........so if you really want the wax to stay ad also to do a good job less streaking etc..) you need good products like 3M, Simoniz, Turtle, Eagle etc.. Some Pros even use just plain water For wax, 3M, Turtle and there are more brands out there.
  14. I saw someone mentioning lifetime ATF, this is false information AFAIK from my little knowledge, this is a story dished by some rouge car dealers towards innocent day to day buyer, and the story has got some attention and I fine people saying the same.
  15. Thanks for sharing, that sucks and these type of user feedback in online communities will help the industry. As an example, I am a user in two different forums (not Automotive) in anther country, the user community there refer the dealers and agents by their name (without asterisks or dots), the dealers and agents do read the forum and officially respond and sometimes correct bad jobs. The forum is so strong and the dealers do not want any one posting any thing bad on them.......... Probably we can do the same........
  16. Agent for Benz, they are the same for OSRAM. Little showroom in front of the Jethavanaramaya near Armour street junction.
  17. Agent for OSRAM is D**O and I have PM you............these lights are bright but shorter service hours compared to OSRAM L (long service time)
  18. Hi Sylvi, please see the above post......this is regarding a factory which I know personally.........they made some usefulness out of Soltron.
  19. D**O, the company whom brings down Benz, Bosch and D*MO........the showroom in opposite of Jethavanarama Temple near Armour's street/
  20. I have no experience, so cannot comment on Petrol and Diesel........... I saw a different thread, where the Subject says Celtron (in error), there were some Diesel guys talking good about it. You may search or follow this link.......http://forum.autolanka.com/index.php?/topic/7637-celtron/page__pid__139703__st__20#entry139703
  21. I am not sure about the agents.........whom is Hay****s I do go for Osram from D**O, they have a full catalog and even offered me to get some specific bulbs imported. Has seen the SilverStar and Cool Blue in country. Cannot remember H5s, but worth trying, at least over the phone. They are helpful.
  22. Has no proper experience on Petrol or Diesel, but there is a Soltron version used for Heavy oil like furnace Oil. I have some information where factories using Soltron mixed with furnace oil, after using Soltron in recommended amounts, following has been experienced. Lowered fuel consumption, quick start up times.
  23. varunatech replied to PMsilva's topic in General
    It is not just plastic, it is a mix of polymers with strengthening materials. And not only Vios most of modern cars use the same. Modern day fuel tank is not just a box, it is a complex shape with many compartments and apparatus for vapor control etc... This polymer material is a help for reduced weight, ease of construction in a complex shape etc.... You do not have to worry about this.
  24. Depend on your vehicle condition, driving pattern etc... following is my experience across few 110s and the measured framework. Measured tank fill to tank fill, no guessing Recommended tyre pressure Clean Air Filter 200,000+ km engine Octane 90 AC on A mix of City traffic to urban (mix of baseline, Townhall to Kandy road) Auto transmission Non aggressive driving 10.2 to 10.5 kmp/l Outstation, not properly measured, guess is over 14 kmp/l
  25. varunatech replied to ashan82's topic in MAZDA
    sent
