Everything posted by GayanR
Cs3 Manual 1.5L
haven't you seen the professionals cs2-limited...
Is This Allowed??
May be the guy who brought it from you reselling it...It's his car now and he can do anything he wants....why waste typing all the things just used your wordings...
Using Tire With Tube And Tubeless Together
I have had some bad experiences during long trips only,flat tire on two occasions...tube doesn't go well with alloys...once the tire and alloy get heated enough there's a possibility of tube melting and cracking over edges,just use it for a while and replace a new tire if you want to save a hassle....
- Motoring Scams In Sri Lanka
Car Jerks When The Clutch Is Used Too Often
engine/transmission mounts?hotspots in flywheel?for a temporary fix try increasing your throttle cable response,if the clutch peddle is adjustable try that too to where you are comfortable...if your clutch releasing point is near to the top of the peddle try moving your seat backwards a bit till your leg is not curved once you push down the peddle,then you can smooth out the upper portion.if the releasing point is near to the floor try the other way..in traffic your muscles might be getting strained and you may be releasing the clutch too quick...
Honda Insight Or Prius 2009-2010
- Car Is Not Speedup When Accelerating + Bad Smell
Do a alignment and a wheel balance...pitstop would be good...if the whole car is shaking check the engine mounts too...- Car Is Not Speedup When Accelerating + Bad Smell
well you can get away with just replacing the clutch plate if the pressure plate,bearing are in good shape..you may need to to machine the flywheel...can do them under 15k...but if you are going for a clutch kit you can avoid future hassles... kit price depends on the brand...if you have replaced the clutch 2 years back may be you are riding the clutch or the one replaced was a cheap clutch plate...first check the break binding issue and see...- Interior Cleaning Is Good Or Bad
Dash and britol seems to be decent products...if it does the job why don't go cheap...cleaning products always include same ingredients...so does your premium brand include gold dust in it?before applying it everywhere you can try applying for a smaller area and see if it has any negative effects...- Corolla 121 Vs Nissan Cefiro A33
Grow up man...god.....lol...anyway drive with overdrive off....you are gonna screw your car finally by this race....try this before the race- Corolla 121 Vs Nissan Cefiro A33
This is so funny.......are both automatics?- Honda Es8
yap this is original shine by dash..that is for vinyl ,leather and rubber parts only.it does have some cleaning properties,but more for a oily gloss..do not use this on seats or any fabric...- Interior Cleaning Is Good Or Bad
no the yellow bottles are for shining vinyl and leather,they are kind of oily,can be used as tyre shine as well,upholstery products are in transparent spray bottles..like air freshner bottles...dash and britol are good products..- Interior Cleaning Is Good Or Bad
This guy isn't satisfied with his service station...- Interior Cleaning Is Good Or Bad
Very clean car...- Car Seat Repair
- Car Airfreshner
I now use this "black Ice" by little trees.....that stick like thing you can hang on the mirror.Amazing fragrance..it has a cover scale for around 2 month which you can remove week by week so it doesn't over fragrance...I have used those ones you can clip on the vents...but i have had very bad experiences by two of them leaked and melted my dash and vents...bdw i havn't tried ambipur yet...seems to be a bit good solid unit by the look...- Interior Cleaning Is Good Or Bad
Buy a good car upholstery cleaner fabric/vinyl or a simple interior cleaner spray...same product...always works for me....just spray and leave it for a minute or so and wipe the seat with a clean cloth....- Buying A Vehicle For 2.4 Mil
how about a honda Hrv http://autolanka.com/ad.asp?ID=129200- Best Petrol Efficiency
I feel bad for these cars....- Best Petrol Efficiency
Don't fall for this someones new found ideas and electronic gadgets and stuff..if they do increase fuel economy that way either the car factory would install it or will mention it in the manual.The best fuel for your car is stated in your car manual...what ever you do things like this you car won't act like a hybrid...even if it does it wont be by a huge margin may be 5km more for a fuel tank...just change your driving style to a calm manner and keep your engine tune to its maximum efficiency that way you'll save more...if the car lacks fuel economy change it for a another one which does good in fuel...- Reducing Water In The Radiator And Mist On The Windscreen (Inside)
Better if you can clean up the a/c system that water on the left side carpet is due to blockage of a hose you can easily clean it...open the bonet and and check the passenger side wall for a small horse or a opening....that mist may be also due to some blockages in the vent holes...anyway for that radiator problem first check whether the radiator cap is leaking...may be the fixed radiator area leaking again...worst case could be a gasket...- Car Security System
Hi sira i think all the basic security systems works that way...my inwell one acted the same way...but haven't experienced leaving the key inside for a while...anyway why did you disable all those good options?in that locking case i think you should have gone with the smart key system which is around 18k...838E one which has a transmitter that you can keep in the pocket....anyway don't think on that too much it will become a habit once you start to leave the car..you'll have to lock the car without letting it to lock itself...just always take the keys lock the car and go.. - Car Is Not Speedup When Accelerating + Bad Smell
