Everything posted by maithri
<-- Vehicle Engine Exhaust Test -->
Hi, Yes I did see it, sorry just a little busy the last few days. Yes land rovers are tested just like all the others, not really a major problem, how ever turning down the pump to reduce fuelling at maximum throttle setting is known to happen at some diesel specialist, but most do not need anything doing to them, just clean filters and a well set up pump is all they need, they are working vehicles here and are looked after as such,may not be polished and gleaming but mechanically sound as break downs cost far too much for the farmers etc who mostly use defenders. How ever the Chelsea tractors-the dicovery's,Range Rovers etc have far too much money spent on them for them to fail! Maithri
Guys, I feel there are far more urgent needs of the Sri Lankan motorist that the authorities need to address long before they join the eco band wagon and start testing emmisions. How about the standard of driving, following the highway code, better parking facilities, and even better quality fuel, all the above I am certain will reduce our oil consumption dramatically, but probably not put more money in the pocket of the treasury or favoured businesses! in fact less due to the loss of fuel tax, as whilst all of you are stuck in any one of the main roads in to colombo due to some muppet calling himself a bus driver plays the pick up game and the three wheelers playing merry go round him without a care for the rules you are wasting fuel,and time, both not renewable! How ever you are buying Fuel and paying your hard earned Rupees as tax to the wonder boys running the diyawanna asylum. Sorry, that's my rant over, to the technical question-HOW BEST TO PREPARE FOR THE TEST try the following, Make sure your engine is properly maintained, has a air cleaner that is not clogged, has had a regular oil change as is not over due for one, is free of any rattles relating to excessive mechanical wear, and the cam belt has been changed at the correct interval,the exhaust is free of excessive leaks-a small blow is not likely to foul the readings too much. Then take a drive in Sri Lanka's heat probably a 3 or 4 mile one will do to warm things up nicely, the worst enemy of an engine is being revved from cold, and make sure your cooling fan is working as the test is done when stationary and will not cool the radiator as a result of air passing through it. I thing the above will be ok for a normal car,small van etc. Maithri.
Hi, I test vehicles everyday in the UK, Diesels are a little difficult as we need to ask the driver about the maintainance history of the engine, if the cam belt is due we refuse to test-not fail-just refuse to test as the test involves running the engine up to it,s governed limit up to six times-refuse to test if the stops on a pump look like they have been tampered with- or low on oil or sounds like a bag of nails, just as easy to wreck the same engine on your daily drive when used normally if not properly looked after! The petrols are revved upto around 3000 RPM and held there for 30 seconds at least, again if your engine cant do this it's not capable of powering your car on the road,even if you think revving it to this amount is bad and change gears every yard to keep the revs down! (some still do this-I was in SL in August) The whole MOT test in the UK takes arond 45 minutes-the emmisions take around 5 minutes of this time. What on earth do we need to spend 20 minutes for? Lower emmisions means lower cost to the owner generally, it saves your car and money in your pocket as well as health benifits to all and lower outlay of precious foreign currency for the country. Why are we trying to lie to the test station about the condition of your engine only to blame them afterwards for a wrecked engine? I am sure they will refuse liability. Just look after your car properly, stop wasting money on frivolous things for your car and treat it's engine with a healthy amount of care and you will have nothing to worry about. Maithri
Vehicle Emissions Testing In Sl
Hi, Pre 1970's cars should not be subjected to measured tests in the UK, We just look at the smoke emitted visually so a poorly set up car is very easily identified. With any rule or law an allowance is normally made to ensure retrospective effects are not draconian. To ask a pre 1975 car to pass todays standards are a farce. I hope the law in SL does not require this to be the case. If it is, all it takes is a fundamental rights case by someone who no longer can go to work in his Morris Minor to ask for legal redress. I am sure our courts still have learned Judges unlike the lot in our Parliment where the brain cells appear to be at a premium. Maithri
Lambda looks too high, have you got an exhaust leak? If so all the other numbers may be contaminated by too much Oxygen as indicated by the lambda reading, if you have a leak proof exhaust you are running a fuel air mix that is too lean. By the way a V6 in SL?? Maithri.
Thanks Devinda, The limits are similar to ones used by the Uk in the early 90's mostly for non catalyst equipped cars. You may find these are really easy to achieve in all cars, with or without catalyst, in fact if your HC level is higher than around 200 you are throwing your hard earned money on the street as you drive! Cats have very little effect on HC-Hydrocrbons meaning un burnt fuel-so the lower this reding is the better your pocket performs-as low as 50 on a non cat car can indicate complete combustion you will get in a well maintained engine in good condition. The CO or Carbon Monoxide content is normal at 2 to 4 % before the cat and the cat will split this down to under .5% and release it as CO2 instead. So the limits seems to be very realistic and fair to all, I tested a car this week that failed due to it's CO reading 4.24% when it should have been under .3%. On investigation we found the cat had broken up and dissapeared down the exhaust pipe, it was a poorly maintained car and still only read 94ppm on HC. We simply replaced the cat and the readings dropped to .08% CO and around 60ppm HC at an engine speed of 2500 to 3000 rpm. It passed the test and the owner was happy even though there were many things he could have done to improve his fuel usage further. Some times we need to do the minimum to suit the customer pocket in the short term! So this law may do some good to all of you as well as to the owners of the testing stations set up there! As you know I test a a lot of very highly tuned Subaru's and I hace seen some of these almost get through the test without a cat so the argument for removing a cat to improve performance is a poor one-there are many more things far easier to do to gain the same advantage. The cat should be the last thing to go not the first if you are seeking higher performance-leaving the wife at home is almost as economical depending on how heavy she is! Sorry no offence meant to the lovely wives we all are lucky to have! Maithri.
Power Steering Woes :(
Hi, It is natural for steering racks to wear out with time, especially if the car is nearly 15 years old, the seals will perish and the rack (the metal rod with teeth cut into it through the middle) to wear on its shaft. New seals will not remove the wear on the shaft this will need to be replaced or filled with a metal welding technique and re machined to it's original size, then the final finish is critical so the seals are not damaged by even microscopic sharp edges. So called re conditioned parts must be repaired to these exacting standards, is the ones available in Delkanda just old units with new rack ends and rubber boots with a layer of new paint? or are they stripped inspected and re sealed with new rack ends and boots fitted, if so it should be better than your used option as you do not know how used the part is, it may be more used than the one you are removing-just not leaking oil yet! So the pitfalls are many but I feel for you, it appears your garage was not wrong in re sealing the old ones if they inspected and corrected any wear on the shaft but the machine work may not be up to standard, hardly un common even here in the UK. I know I am asking more questions than answering your question but these I believe are the questions you should ask your garage and the vendors of the parts you buy. It's a shame we cannot establish a proper re conditioning set up in Sri Lanka, with our high skills and low labour cost (JVP-Forget it) we could supply the western market easily with stuff like this at a good profit as long as the machinery is available. Maithri
Hi, Terrance can you please post a few details of your car, and what the test was for, i.e.co,co2,HC,NOX etc and what the limits were etc. I am sure someone has tried to access the Govt.Dept web site to find what the rules are how often the test is done,the test fee, etc.I am just curious, but I am sure the SL motorists are quiet concerned if they are in the dark as it appears according to the post here, ignorance creates a culture of fear and trepidation, so education is the best way to avoid this. Maithri.
2008-9 Subaru Impreza Wrx Sti Spy Photos
Sorry Friends, I will not bring anything to SL that I can't carry in my suitcase again. I shipped a box of toys and clothes to be given to an orphanage in August when I came down, and wasted nearly 5 hours of my time collecting same from C*l near the lake house. The idiot's were after a bribe or something what a mess, never again I am not good at mixing with corrupt officialdom I just get mad! and even though I could have pulled strings I don't like that either so I suffered and cursed them at the top of my voice inside their building! I really felt sorry for Sri Lanka's real foreign exchange earners, the people who work in the middle east who were treated like dirt and had their hard earned property robbed by these theiving hooligans to add insult to injury. Maithri
Hi Guys I am freinds with a specialist Subaru tuner whose workshop is just a few doors from me, his engines regularly exceed 400bhp, and he races his own scooby, so there is more wolves in sheep's clothing than you imagine here in the UK! Maithri Check out www.zenperformance.co.uk.
Turbo Trouble
Hi Whatever else is blanked off make sure the turbo wastegate vaccum pipe is clear, the wastegate is really strong and requires a strong vaccum to operate, so no blocked activating pipes! The EGR is different,by the way if possible get it to work as well. Maithri
Rust
Hi, I still admire the classic mini, recently I had a pleasure of seeing one of the last classic mini's produced in the cooper edition,around 1999, it was in super condition, how ever I was dissapointed to see very little had been done to protect all the problem areas despite the technology being freely available! I would start by stripping the entire car down, remove the interior, engine/gear box, both sub frames including the electrical wiring. This will expose the metal work, look carefully at the a pillars (where the doors are hinged) if possible remove any under seal inside the wheel arches, look also where the rear sub frame is attached to the car as well as the floor pan. Every panel is available here in the uk from specialist Mini suppliers at reasonable cost, look up the internet and you will be amazed, repair what you can and cut away and replace what is too badly gone, then protect all the seams with the best quality seam sealer you can afford, then spray the whole of the under side with paintable body shultz (try 3m) before doing the cosmetics, install all the glass, electrics and the Treated sub frames along with engine/box and enjoy for many years to come! Also if you can get a good cavity wax like Waxoil spray it into all the cavities to protect the metal inside out, this can really help when it is not possible to reach these areas to protect them. Maithri. P.S. Secret is finding a good body work man (tinker) as a muppet will kill the whole job! Maithri.
Turbo Trouble
Hi, Blanking out the EGR has little effect if your turbo is ok. When the EGR is faulty the loss of pressure causes the vehicle to loose power and emit excessive smoke from the exhaust. Blanking it off will only remove those symptoms and restore power, it will cause higher NOX emmisions due to higher combustion chamber temperatures but little other harmful effects.If your turbo whines which is not un common on these it may not be faulty, just a little worn, I presume you bought a second had used vehicle, it will not be in a like new condition. Before too many conclusions are thaught of make sure the noise is not from a split hose, pipe or a leak at the inter cooler, in the intake system. These are a lot more common than a faulty turbo. Turbo's are fairly straight forward mechanical turbines and have very few parts that break, and a damage turbine blade will not last long without the whole unit failing due to the speeds at which it spins, and a turbo less turbo car is pretty hard to drive due to the seriously low pulling power. So get some one who knows the engine type look at it, the EGR is not so important, but it will be better if you can restore it to working order, sometimes all you need to do is clean the valve throughly to remove soot and gunge to restore it to working order. Maithri.
Car Is Having A Heating Problem. (opel Astra 1999)
This is a common car around here in the uk. The cooling fan has no fail safe device so if the thermo switch fails it will not switch on and cause the car to overheat. These are common for water pump leaks-the pump is driven by the cam belt so a little hard to see, the fan belt does not form a part of the cooling system apart from driving the alternator which provides electricity for the electric fan to run.The coolant tank is clearly marked with MAX so you should not over fill it as this does not leave any space for the hot coolant to expand into. The down side of this car specially in the 16valve configuration is they will start leaking from the head gasket if you allow the car to over heat, or due to cavitation caused by poor quality coolant. If you are removing the cylinder head be sure to use new head bolts and tighten according to the manufacturers set angle torque settings. If the leak is from the water pump, noticable from the drip of water at the front of the engine when running replace the cam belt and all the idlers and the tensioner pulley together as these are due for change with a cam belt and prone to failure once past their recomended milage. Hopefully you have looked at the very obvious things like the radiator and hoses as well. Maithri
Tyre Help...
Hi Guys, I have just checked a wholesaler I buy from here in the UK and they list Michelin Primacy, Pirelli p7, P Zero,Dunlop, Goodyear,Nexen and Wanli in this size from stock. So If you can find a local tyre dealaer for any of these brands you should be able to get them. If you go for a different profile tyre be ware that lowering the profile from 50 to 45 may cause a loss of comfort as the tyre has less cushioning to absorb the pot holes and may damage easily as well. Maithri
Seatbelts Compulsory
Guys, Just a few facts-In the UK there is no need for seat belts if in the front on cars built befor a cut off point in the 1960's I know the date if I was at work as I am a MOT examiner. Any car sold as new in the UK since had to have belts for the front seats in order for them to be type approoved-So No seat belts No new car! The rear belts started being fitted in the late 70's and became necessary for type approoval in the 80's-they were testable at the MOT from that day onwards models. It was very recently in the late 90's that wearing the rear seat belt became compulsory or was it early 2000's? All that said I am a great fan of seat belts and child restraints as it saves many lives and horrific injuries.My principal is if belts are fitted wear them! How ever do not be tempted fit seat belts on a very old car without factory provided threaded mounting holes. The stresses on a belt mounting during a high speed crash can be like an elephant trampling it and such a belt may be more dangerous than going without one! To draft and pass legislation requires a degree of intelligence and education as well as a collection of expertese in the subject. Do you think we have a civil service capable of doing such drafting and a parliment capable of analysing debating and adopting such complex technical legislation? Maithri.
Auto Dimming Rearview Mirror
Guys, A lot of VW's had this type fitted since the late 90's, needs a power supply as it uses a photo sensitive cell to detect a car behind you with lights flashing at your mirror and activated a motor to dip it automatically. Never seen an after market supplier of these, may be the internet can help you there. Maithri
Fiat 500
Hi Guys, I saw this car the 500(new) one a few months ago at my local dealer. They looked so close to the original iconic 500 that I remember which my uncle owned. I think Fiat has done a truly wonderful job of bringing the past into the future. I wish I had the resources to indulge myself, the new 500 I feel is closer to the original than the new Mini is to it's iconic original or even the Beetle which came very close! Maithri
Gps Map
HI, Light hearted comment guys, I do not have enough exposure, or knowledge of the violence in SL to really know what is necessary to protect the general public! I will not preach from the comfort of my home in England. That would be an insult to those who genuinely lay their lives on the line for for our country, to safeguard all who live in it and love it. I have only the highest respect and regard for them and would not dream of endangering any one of them! So as the English saying goes, "if the cap fits...." Maithri
Gps Map
Guys, I did not mean to hide my phone from the customs, it is such a common item in the hands of almost every one and almost all the foreign tourist who arrive in SL a little information somewhere in the air port, web, in the air craft or something would alert every one that they are about to commit and offence in SL would allow most law abiding people either to declare it or to leave it at home etc.etc. On another note I think it is a stupid and an un enforceble law and an un-necessary infringement on the liberty of the general man on the street. How ever in a country full of stupid politiciens from all sides a stupid law is not a surprise. Maithri
Part Of A Petrol Engine....!
I think it's the evap canister too, if it has wires plugged in it almost definitly is the charcole canister for the evap. This keeps your petrol tank vapors and when suitable releases them into the intake side of the engine to reduce pollution frfom petrol vapors being released to the atmosphere. Maithri
Srilankan Talant 80km Per 1liter Of Water..?
Hi, A friend of mine in the motor repair business is trying out a device which feeds Hydrogen extracted from water in to the inlet manifold of a car. I saw his Peugeot 307 2.0HDI last week complete withe bubbling water container in the boot(dickie) and a hose feeding the inlet pipe at the engine bay. He says it has doubled it's Miles per gallon figure! I carried out a smoke emmision test on it and and it read very low smoke particles on full revs on a 144000 mile old diesel engine. I have been told that the NOX emmisions may be higher than normal but I havent got the equipment to test that. So may be this story of this guy has some truth in it, as for running entirely on hydrogen extracted from water I am being advised that it then will become a perpetual motion machine which is impossible! Maithri.
Gps Map
Hi, I had a GPS enabled phone on me during my recent visit to SL. Nobody asked me any questions on my arrival at the Air Port. It was fun locating where you were and on one trip we had left it on and it told us how far we had travelled the altitude etc.etc.! Then on a visit to a well known gadget mall in Colombo I saw the very same phone for sale! So what is legal? Maithri. P.S. To the customs men I brought it back to the UK on my return!
Abs Indicator
Hi, Most ABS problems are caused by wheel speed sensors. A simple way to test for this is by measuring the resistance at each sensor by un plugging the connector at the wheel end or at the next connexion. Compare the readings using a simple multi meter. The one that is very different or showing an open circuit is the likely culprit. Make sure the ignition is off and if possible the battery is dis-connected before you start. If this shows no fault check the same readings at the ABS ecu wiring plug after disconnecting it from the ecu-the ecu is normally attached to the abs pump and valve unit in the engine bay. You will have to identify the wiring by colour code traced from the connector at the wheel end, normally the same in most cars except the french, they use numbers on the wire which are very difficult to read. In most cases these two will elininate problems with sensors. The next test is using the same multi meter to sheck for voltage. That I think is a bit too long winded, but if you can get this far and find no fault I can help you do this. Good luck Maithri.
Audi / Bmw / Vw
Just an R32 golf-Brand new demo car when I used to work for a VW dealer! Maithri.
