Hi Guys.......
I bought a carina gt car (year2000)and i need to know how is the car market and the availability of engine parts in srilanka ..... if so where can i buy.................. and other thing is fuel consumption.....
Thanks.......
13 answers to this question
Hi Guys.......
Thanks.......
hi dude
first of all congratulation on purchasing carin gt. engine parts are freely available and try toyota dealers because some parts are only found at agent e.g. fuel filter.if your car is manual transmission it do 8-10 kmpl around city in outstation it do 11-13 the fuel figures mostly based on your driving style. :)
Edited by nexus
Hi Guys.......
Thanks.......
Wow congrats mate. this thing got the 4AGE engine which is quite different engine compared to other Carinas. is it a black top or red top (I Mean the Engine)?
Edited by Ruslan
hi Ruslan
i thought carina gt only come with black top engine. and what is the difference between black top and red top engine
hi Ruslan
blacktop and silvertops are 20 valves. redtops and bluetops are 16 valves.stuff is interchangeable to a point. older bluetops have smaller internals. redtops have an oil drain line from the head to the block. you can use redtop pistons in a bluetop if the wrist pins are the correct size. you can use 20v pistons, but if you dont set the timing belt properly, first time, startup will bend valves. go to the REFERENCE section, go down to Section 2, click the first one up top.
im using a silvertop block, crank, and rods. matted to bluetop pistons(late model 20mm wrist pins) modded to clear the oil squirters. bluetop head, intake system, ecu...oh yeah, and redtop, high comp, 235cc injectors-all in my ae86
so a combination will work if done right. read up, search a bit. theres a bunch of people who have these "franken-motors".
bluetops also have larger intake flow, they are called largeports. the bluetop cams have more lift, 0.4mm iirc. redtops have higher compression.
http://forums.club4ag.com/zerothread?id=40388
hi dude
agree on this a lot...drive casually u save up...drive like crazy gonna hurt ur wallet....but really cant help it sometimes coz its just a fine ride
as far as i knw there was no redtop right?
its only black n silver with slight difference in HP...of which the black has a bit more
Hi Guys.......
Thanks.......
Thank God you bought a carina!!!IMO there will be no problem for market and the spare parts..
But its always better you look for ideas before you buy the machine!!Bcs once you bought its your Baby dear!! :)
Thanks guys for your early reply.... I got BLACK TOP carina gt .I bought it for Rs2.3 Mn (Year of registration 2003)Is is worth for that amount.....
Thanks guys for your early reply.... I got BLACK TOP carina gt .I bought it for Rs2.3 Mn (Year of registration 2003)Is it worth for that amount.....
hi chamee
if the car is in good condition it's worth amount you pay, now you are the owner of the car it doesnt matter anyway so dont worry abut the amount you pay just enjoy the car :D
and btw it is a manual or auto and what is the year of manufacture
