Hi ppl,
My father car which is a 99 model FB 15 was serviced at pitstop two weeks back and during the service they have mentioned that the alternator cable needs to be replaced. Then from the following day while driving the battery indicator poped up.. and after few seconds it switched off and this behavior is taking place frequently.
We replaced the alternator cable and the indicator dint pop up for some time and it started to show up from yesterday again. Whats hard to understand is that it the indicator stays on for very few seconds.
Please help me out here. What can be the issue?
Now the issue can be the battery. If you ran without it being properly charged (the alternator cable being bad), then the battery might need to be replaced now.
You could get the battery checked by a battery selling spot, but usually they will say your current battery is bad, cause obviously it would lead to a sale.
If I were you, I would go to a reliable garage and get the battery and related gadgets checked. (I mean the alternator, cable, the belts etc.)
And I'm pretty sure our experts might have answered same / similar questions previously on this forum. Why don't you do a search?
:grinning-smiley-003:
If you want to get the battery checked try Br*wns battery joint at thibirigasyaya. But like ae100 said its best to check all of your battery related components.
Hi mates,
Thanks a lot for the response. We did check the battery from the Thimibirigasyaya joint they said the battery is fine. Now after replacing the belt the garage bas sadi the alternator is doing fine.. Can this be an issue of a sensor?
Hi mates,
I,m 90% sure the issue is with alternator. Go for car Electric/ Batery shop. Tell the issue to the mechanic. He'll get the alternator out. And he'll have to open it. There are 2 Pins which are very critical for the electeic supply. (I dont really know what those node are called.) Anyway those node has to be cleaned. (might b used sand paper) Then reinstall the alternator. This will solve ur issue.
Good Luck!
Hi mates,
Buddy did u get the Alternator Belt tension checked ?
Loose belt will not charge the battery :)
Edited by kelum_wj
