Recently I checked out a friend's 2003 Suzuki Swift 4WD (groan!) to give a bit of a blind-leading-the-blind style automotive advice :D
Anyways I noticed that there are plenty of things wrong with the car - starting from a constant jada-jada sound from the front left side wheel area, even on a carpeted road. Sounded like suspension bushes? or maybe even the shocks.
Also the steering wheel is kinda easier to handle than usual, which I feel, could be a problem with the steering rack or rack ends. The steering wheel got stuck for a wee bit when i made a full left turn.
The point is, the car seems to need the attention of a good mechanic who can identify the problems and rectify them. Probably needs attention for things like the steering rack, suspension maybe even CV joints and stuff.
Can anyone recommend a good garage, preferably in peliyagoda-wattala area who can do the repairs, keeping in mind that its a 4WD. Any advice on the above problems would be appreciated.
PS. I also noted that when I tried to check the engine oil level, the fluid that appeared on the dipstick was PINK. Was I checking the ATF fluid by mistake?
PPS. JDNET are u still running your garage? Wanna take up this challenge?
5 answers to this question
there is also a place in kerawalapitiya junction hendala, man's name is stanly....donno abt 4wd cars..but the man analyse...explain ..and give solution...
weird... I'm staying in Hendala myself...never heard of a good mech around here so prefer to take the drive to seeduwa.
will check up on this stanly fellow
