malinda7 Posted July 8, 2011 Posted July 8, 2011 hello guys just wanna know if the vehicle engine under compression, does it make any impact to fuel consumption? also what are the other symptoms that you can find. also what are the solutions for this issue. need your advice. Quote
The Don Posted July 8, 2011 Posted July 8, 2011 hello guys just wanna know if the vehicle engine under compression, does it make any impact to fuel consumption? also what are the other symptoms that you can find. also what are the solutions for this issue. need your advice. Yes it does have an impact on fuel consumption, as the engine won't be producing as much power as it did before. But really the more obvious symptoms would be, difficulty to start the car in the morning, white smoke coming out of the exhaust during the day time, loss of power, loss of oil (oil levels going down without no apparent oil leak) etc. In diesel vehicles some of these symptoms may be more obvious than petrol. Quote
malinda7 Posted July 8, 2011 Author Posted July 8, 2011 Yes it does have an impact on fuel consumption, as the engine won't be producing as much power as it did before. But really the more obvious symptoms would be, difficulty to start the car in the morning, white smoke coming out of the exhaust during the day time, loss of power, loss of oil (oil levels going down without no apparent oil leak) etc. In diesel vehicles some of these symptoms may be more obvious than petrol. thanks for the valued reply. according to the symptoms what you have mentioned above doesn't have on mine. garage person said that the engine is under compression because there's a oil(little amount) in the Air filter area. so hiz concern is due to the under compression fuel consumption goes low. and he recommended to do the overhaul. any help on this matter Quote
The Don Posted July 8, 2011 Posted July 8, 2011 thanks for the valued reply. according to the symptoms what you have mentioned above doesn't have on mine. garage person said that the engine is under compression because there's a oil(little amount) in the Air filter area. so hiz concern is due to the under compression fuel consumption goes low. and he recommended to do the overhaul. any help on this matter Well before you decide what to do next, get a compression test done on your car. Any competent garrage can do it but make sure it is not the finger in the spark plug hole test. You need something more scientific than that. Oil in the air filter area is not a good sign but you need to confirm the problem before thinking about solutions. 1 Quote
malinda7 Posted July 8, 2011 Author Posted July 8, 2011 Well before you decide what to do next, get a compression test done on your car. Any competent garrage can do it but make sure it is not the finger in the spark plug hole test. You need something more scientific than that. Oil in the air filter area is not a good sign but you need to confirm the problem before thinking about solutions. Agree with you. do you know any good place for do this. Quote
The Don Posted July 8, 2011 Posted July 8, 2011 Agree with you. do you know any good place for do this. I think the famous Edirisingha engineering works can do this, but find out from your mechanic if there is a local place that can do the same. Also inquire from local garages, it's not the most complicated job in the world. Quote
asanka424 Posted July 8, 2011 Posted July 8, 2011 I think the famous Edirisingha engineering works can do this, but find out from your mechanic if there is a local place that can do the same. Also inquire from local garages, it's not the most complicated job in the world. Juki workshop pepiliyana. They test compression. But make sure you read the values rather than listening "good or bad" by the tester. Quote
malinda7 Posted July 8, 2011 Author Posted July 8, 2011 I think the famous Edirisingha engineering works can do this, but find out from your mechanic if there is a local place that can do the same. Also inquire from local garages, it's not the most complicated job in the world. I hope your referring to the peliyagoda place. Quote
The Don Posted July 8, 2011 Posted July 8, 2011 I hope your referring to the peliyagoda place. This is the place http://www.eblautocourt.com/ Quote
maheshw8 Posted July 9, 2011 Posted July 9, 2011 u can also check the under compression by this way,, start the engine, remove the dipstick & rev it,,. if u can see oil is spitting off, that would be under compression, may be your worn piston rings, Quote
toyota sucks Posted July 9, 2011 Posted July 9, 2011 If there is more space between the hole and the thing that moves inside the hole there is undercompression Quote
Ripper Posted July 10, 2011 Posted July 10, 2011 u can also check the under compression by this way,, start the engine, remove the dipstick & rev it,,. if u can see oil is spitting off, that would be under compression, nope. i can assure you that this does not work. I've seen engines with under compression, smoking, burning oil etc but not blowing a drop of oil through the dip stick vent hole. Quote
miniace Posted July 10, 2011 Posted July 10, 2011 Well before you decide what to do next, get a compression test done on your car. Any competent garrage can do it but make sure it is not the finger in the spark plug hole test. You need something more scientific than that. Oil in the air filter area is not a good sign but you need to confirm the problem before thinking about solutions. Agree with Don, compression test is the first step. Then you can determine the level of repair to be done. MINIACE Quote
tiv Posted July 10, 2011 Posted July 10, 2011 nope. i can assure you that this does not work. I've seen engines with under compression, smoking, burning oil etc but not blowing a drop of oil through the dip stick vent hole. If you use a thinker oil mixture, there won't be any oil shooting out, This technique is practiced my many used car sales etc Quote
miniace Posted July 10, 2011 Posted July 10, 2011 If you use a thinker oil mixture, there won't be any oil shooting out, Thicker I guess ! or High viscosity. MINIACE Quote
malinda7 Posted July 12, 2011 Author Posted July 12, 2011 Agree with Don, compression test is the first step. Then you can determine the level of repair to be done. MINIACE thanks for the positive feedback guys. yeah i agree with both of you. now i need to find a good place for compression test. Quote
NRX Posted July 12, 2011 Posted July 12, 2011 If there is more space between the hole and the thing that moves inside the hole there is undercompression Dirty minds Quote
Gihan1234 Posted November 11, 2018 Posted November 11, 2018 My disel car having a problem. I when the engine oil cap removed air is exhausting like a silencer.blackish air is poping out. Also when the engine stopeped after a travel. It cant restart and usually can start after 20/30 minutes . May know the problem . Quote
Twin Turbo Posted November 11, 2018 Posted November 11, 2018 On 7/8/2011 at 5:01 PM, malinda7 said: hello guys just wanna know if the vehicle engine under compression, does it make any impact to fuel consumption? also what are the other symptoms that you can find. also what are the solutions for this issue. need your advice. Q: What is your vehicle and its current mileage? TT. Quote
