I'm a victim of using contaminated petrol. Experienced engine missing at 1000RPM and later on, cleaned injectors using BG Injector cleaner. Thereafter engine missing issue was resolved. But I started experiencing engine delayed start.
Vehicle: Toyota IST - 2008 - 1NZ-FE 1.5L engine
Description:
When starting the engine, starter motor kicks in about 2 seconds to start the engine. When you turn off the engine and starts the engine within 2 - 3 minutes, it starts instantly. But when you keep it for around 5 - 10 minutes, previously explained delayed starts occurs.
What I did so far:
I took my vehicle to Toyota and they checked the fuel line pressure and said there is a pressure drop. So they advised me to replace the fuel pressure regulator in the fuel pump unit. Still I'm experiencing the same delayed start issue. Toyota Lanka technicians are unable to find a solution for this. When they plug their computer terminal to the vehicle OBD2 port, error is reported as "Vehicle Starting Issue".
There were few other customers were there experiencing the same issue. I got one of their contact numbers and they also told me the same thing. There is no improvement even after taking it to Toyota.
Note: I cleaned my injectors manually, Cleaned throttle body, there are no vibrations, engine is running at optimum efficiency.
I really appreciate if somebody can at least give me a clue for the delayed starting issue.
Nissan is bringing in the Primera nameplate back. I hope it's not going to be some boring crossover but a car that will have superb handling, good responsive reliable motor like the Primeras of pre 2000. I also do hope they don't go under and the Primera becomes their saviour.
https://carbuzz.com/nissan-trademarks-primera-name/
Hey Guys,
Sorry for the downtime over the past two days! We’ve been migrating servers and upgrading the site. You might still experience occasional outages as we fine-tune things.
Thanks for your patience! 🙌
Chulanga
Dear Experts,
Description:
What I did so far:
25 answers to this question
