dhejasvini Posted September 9, 2011 Author Posted September 9, 2011 thnx guys i got through the green test by a thin margin...by doing a fuel system cleanup at auto M.... but now i feel less power some time the engine slow down unusually(rpm drops)..and fuel consumption also bit increased ..is this called engine missing??? Quote
jdnet Posted September 9, 2011 Posted September 9, 2011 thnx guys i got through the green test by a thin margin...by doing a fuel system cleanup at auto M.... but now i feel less power some time the engine slow down unusually(rpm drops)..and fuel consumption also bit increased ..is this called engine missing??? When the RPM goes down, open the bonnet, see if the engine is there. If it's not, your engine is missing. Quote
jdnet Posted September 9, 2011 Posted September 9, 2011 but seriously, did you inspect the spark plugs? might be time to stick new ones in there. Quote
dhejasvini Posted September 9, 2011 Author Posted September 9, 2011 When the RPM goes down, open the bonnet, see if the engine is there. If it's not, your engine is missing. gud one bro..but seriously still i dont know what is engine missing...ok..but how to identify the bad spark plugs? Quote
jdnet Posted September 9, 2011 Posted September 9, 2011 gud one bro..but seriously still i dont know what is engine missing...ok..but how to identify the bad spark plugs? First of all look at the plug and check the electrode (the top metal part) and insulator (the white part) for deterioration. basically if the electrode has excess deposits and is rounded off it's bad. Your mechanic should know about it. Did he tell you why you have a misfire? atleast what he thinks about it. Quote
dhejasvini Posted September 9, 2011 Author Posted September 9, 2011 (edited) i didnt take the car to my mechanic since the rpm dropping incident...but when he was doing the tuneup 2 months ago he didnt suggest for new plugs... Edited September 9, 2011 by dhejasvini Quote
jdnet Posted September 9, 2011 Posted September 9, 2011 i didnt take the car to my mechanic since the rpm dropping incident...but when he was doing the tuneup 2 months ago he didnt suggest for new plugs... Then I ould suggest that you change them. Make sure you buy the correct plugs. If someone tries to sell you something just because it fits, don't buy it. Quote
Mani Posted September 10, 2011 Posted September 10, 2011 Very difficult to diagnose the problem you have over the net without seeing it in person. Here's some areas you may want to look into and some are mentioned here by others. O2 sensor operates properly Fuel filter is in good condition Your cat converters, if so equipped Fuel pressure at the rail You can also have too much blow by [worn rings or bad seals] Faulty PCV valve One thing you want to do before the emission test is performed is to make sure the car is properly warmed up. Just drive the care around a bit just before you test it. good luck. Quote
