Dan Wheldon's Indy Car Friends On Tragic Loss; Crash Video Shows 15-Car Pileup
Ohh I use chrome.. I dont see anything (even on this 2nd time load)
I use chrome & IE both and I can view this youtube video clip on both browsers without any prob..
Install adobe flash machan, BTW can you view videos on youtube ?
I can see this one, but this issue comes up from time to time for me too. Generally when there is a bandwidth squeeze. Try refreshing the page.
If that doesn't work, it might be your permission settings, or proxy rules or summin.
From the web.
IndyCar disaster puts safety focus on motorsport
19 October 2011 | By Stuart Nathan
The tragic death of IndyCar driver Dan Wheldon in a race in Las Vegas is certain to put pressure on
all motorsport to tighten up safety, and with a large proportion of all racing car technology based in
the UK, this means that the onus is likely to fall on British engineers. Many industry observers believe
that the failures which led to Wheldon’s death are connected with the format of IndyCar racing itself
and the layout of the oval circuits on which some of the races are run, rather than the technology of
the car. However, the design of the cars is also likely to come under scrutiny, and the regulators of
Formula 1 are as keen as those of the IndyCar series to ensure that drivers remain safe.
Wheldon died in a 15-car pile-up which began when several cars collided, sending them airborne and
into the catch-fences and the outside wall which runs alongside the track in IndyCar oval races. The
race had started with 34 cars, and this, according to former F1 driver and current BBC commentator
Martin Brundle, was a huge factor in the crash. ‘The difference [between IndyCar and F1] is that you
are running four cars wide, only inches apart at speeds of 225mph,’ he told the BBC.
Another F1 legend and a former IndyCar champion himself Nigel Mansell, added that the walled track
was the other factor. ‘In Indy racing, there is simply nowhere to go. When an accident happens you
are into the wall in a split second. This is why F1 does an exemplary job. The tarmac runs off so the
driver has time to decelerate the car.’
The format of the race is a big part of IndyCar’s draw: people have been attracted to watching
dangerous sports for millennia, after all. One option being considered for IndyCar is a closed, jet
fighter-like cockpit, to add an extra layer of protection for the driver’s head.
This is also under consideration for F1, and has been since Felippe Massa was seriously injured by
being hit on the head by a spring which had worked loose from the car in front during practice for the
2009 Hungarian Grand Prix. The FIA, F1’s governing body, has been looking at the issue for the past
two years, and has presented recommendations on cockpit canopies and visor design to the F1
Technology Working Group and the Grand Prix Driver’s Association.
F1 is likely to resist such a change: open-wheel, open-cockpit racing is part of its brand and a big
part of its attraction. But the risk to driver’s heads continues to be a concern, and there’s no doubt
that drivers are protected further by closed cockpits; a serious crash at this year’s Le Mans
endurance race, where cars enclose the drivers completely, caused no injuries to the drivers
involved.
It’s certain that changes are coming in IndyCar, whether to the track layout or the cars, and F1
cannot and will not ignore changes that could improve driver safety. The difficulty is going to be
whether they can change without damaging the daredevil aspect of motorsport — something which
can’t be denied — or the ability of the drivers to race
I have the same problem sometimes...only when someone quotes the video or image it shows...Also having trouble with youtube....is it becoz of google chrome??
Im using firefox 7 and everything is fine for me, must be some glitch with chrome. Whats the version you are using ? It looks like the issue is very common with chrome (http://www.geeksaresexy.net/2011/04/15/chromes-flash-problems-solved-again/)Try installing a newer version, also try doing this [http://www.thewwwblog.com/install-flash-player-google-chrome-browser.html]
