Obd 11 Issue Code P0443
JayZ
Has anyone incured this fault code P0443 or similar?
P0443 - Evaporative Emission Control System Purge Control Valve Circuit
This code comes with the check engine light. I got the code cleared once but still popping up time to time. Any of you had experience with this issue, appreciate your input.
Note: i checked online, "http://www.obd-codes.com/p0443" still did not check this with the agents or a mechanic.
Vehicle - Ford Mondeo MK3
  On 11/14/2011 at 5:02 PM, miniace said:
You have a problem with the purge solenoid unit or the wiring or maybe both.Ask a good technician to remove and clean up carefully and refix. If a scan tool is available he can check the activation manually.
MINIACE
Thanks Miniace,
The guy i checked with didnt knew much about activating solenoid with the scanner. Should check again with a good place.
Btw what is the impact to the engine due to this issue ? Is it a very bad situation which needs immediate attention? I dont feel any issue with the performance of the vehicle.
  On 11/15/2011 at 4:43 AM, JayZ said:
Thanks Miniace,
Mate actually it has an effect on performance.A good solenoid will assist for a good airflow and returning favourable fuel consumption and Bhp.
I have heard even a leaking fuel line or tank can activate P0443 but im not really sure of this. Take your babe to a good technician and not a serious issue.
MINIACE
MINIACE
Thanks again,
would you be able to tell me a mechanical expert for European vehicles and who does cater for these type of issues around colombo ?
  On 11/17/2011 at 5:10 AM, JayZ said:
Thanks again,
Im sorry not really sure of a good guy in Colombo. But if you are willing to drive upto Seeduwa, will tell you about a good place.
MINIACE
Thanks again,
would you be able to tell me a mechanical expert for European vehicles and who does cater for these type of issues around Colombo ?
"jayz'
Contact Mr, Mario Disas. HP: 0777380771or Office tomorrow morning 2581342.
Please note I am not advertising this person, or do any propaganda to him.
AS you were looking some one in Colombo I thought of posting this post.
Edited by Sylvi
