iPrabhath Posted November 21, 2011 Posted November 21, 2011 Hello friends After servicing my car on last Sunday, A/C blower fan (close to cubbyhole) made a rattling noise. After some inspection I found few baby rats on the blower fan. They had used the air cleaner as their bed and bought some paper from outside for more comfort. Anyhow after removing them, everything worked fine. But from today morning there is a problem again. When I turn on the car (move key from acc to on position ) a bad sound comes from engine compartment. Please help me to figure out what the problem is. Thanks Quote
The Don Posted November 21, 2011 Posted November 21, 2011 IPrabath, if you read your own post you will realise why there hasn't been many response. A bad noise can be a million and a half other things and without listening to it, its a little difficult to help you in any meaningful way. Usually the best idea is not to try to start the car, but get a mechanic to come and investigate the problem straight away. It could be something simple like a slipping belt etc but could also be more serious so the less things you do the better, just in case! 2 Quote
Reckless Posted November 22, 2011 Posted November 22, 2011 I agree with Don. Maybe the rats came back and chew some wires or something in the engine. I also think its better not try start the car until a mechanic have a good look in to it. Quote
ShintaroX Posted November 22, 2011 Posted November 22, 2011 Rats battling for their squatter's rights! More info Prabath! Quote
iPrabhath Posted November 22, 2011 Author Posted November 22, 2011 Rats battling for their squatter's rights! More info Prabath! Thanks for the replies Let me clarify my situation little better. Before this problem, When I turn on (not start but turn it on) the car I could hear sound of an opening some thing by a motor.(similar sound from power mirrors) When I turn the car off, same sound is coming which assumed to be closing something by a motor. After the attack , A "kata kata sound" is coming associated with the sounds I mentioned above. I want to locate the place where that opening/closing occur so that I can find some solution. Thanks Quote
The Don Posted November 22, 2011 Posted November 22, 2011 Thanks for the replies Let me clarify my situation little better. Before this problem, When I turn on (not start but turn it on) the car I could hear sound of an opening some thing by a motor.(similar sound from power mirrors) When I turn the car off, same sound is coming which assumed to be closing something by a motor. After the attack , A "kata kata sound" is coming associated with the sounds I mentioned above. I want to locate the place where that opening/closing occur so that I can find some solution. Thanks Does the car still run? The noise you hear when you move the key to the on position is the electronic fuel pump starting. Quote
iPrabhath Posted November 23, 2011 Author Posted November 23, 2011 Does the car still run? The noise you hear when you move the key to the on position is the electronic fuel pump starting. Yes it is running. Quote
The Don Posted November 23, 2011 Posted November 23, 2011 Yes it is running. Could this be coming from the blower if you have the AC on? Often rats take pieces of paper up the ventilation tunnels and they often end up in the blower chamber. My suggestion is get it checked out professionally! No point doing DIY or posting on this forum since the symptoms are too obscure to guess the problem. Quote
c1nder Posted November 23, 2011 Posted November 23, 2011 Maybe the rats messed up the circuitry that controls the blower positions (Front, Feet, Windscreen etc...) if it's controlled by electric motors Quote
