How Can I Know Oxygen Sensor Has Gone Bad
Dear friend How can i identify Oxygen Sensor is bad and to be replaced If vehicle pased the Smoke Emission Test does it mean Oxygen Senor is good and even
my car shows up as a check engine light or malfunction indicator lamp illuminating in the dash board. Can i check this simply or should i go to garage for OBDII code checker is there any thing can do for me using normal toolkit at home (DO IT YOURSELF) but in my case fuel consumption is ok.
3 answers to this question
In some cars, there is a way of getting the error code without plugging the car to a diagnostics system, but I propose that since they don't cost too much you do get a diagnostic report done.
Without the diagnostics report its difficult to assume the cause of the problem.
A car can pass an emissions test with a faulty oxygen sensor. They need to be changed periodically like spark plugs but I don't think this is done in Sri Lanka. A more notable symptom maybe a loss in fuel economy.
remove the socket connecting the O2 Sensor to the circuitry. and start the engine. while the engine warms up get a regular multi-meter and check the voltage produced by the sensor. if its between 0.2 V and 0.8~0.9 V then your oxygen sensor should be alright. ideally it should be hovering around 0.45 V (450 mV) for the best balance of fuel/Air (provided that your environment has the right amount of oxygen when testing)
this is a simple test you can perform,
Edited by MiraOwner
If O2 sensors like those connected to catalytic converter goes bad, there will be dashboard indication.
If u unplug the connectors, indicator lights will go away, so that u can confirm...
