SLA Posted February 7, 2012 Posted February 7, 2012 There are some numbers and letters written on newly replaced dashboard. may be they have written it using a permanent marker or somethin like that... can someone please suggest a dashboard cleaner to get this mark removed. Quote
JadeyBlitzen Posted February 7, 2012 Posted February 7, 2012 a tiny bit of kerosene on a soft piece of cloth should do the trick. takes ages but it won't damage the plastic unlike thinner or brasso Quote
Sylvi Posted February 7, 2012 Posted February 7, 2012 There are some numbers and letters written on newly replaced dashboard. may be they have written it using a permanent marker or somethin like that... can someone please suggest a dashboard cleaner to get this mark removed. 'SLA', Can you describe you have letters on the plastic area or on the other leather cloth area. As for previous post can try k oil if not you have to use Son of a gun dash board cleaner can. With a old soft tooth brush. Can try Tpol cleaner also. Sylvi Wijesinghe. Quote
Scooter Posted February 9, 2012 Posted February 9, 2012 Also, gently but liberally, write over the permanent-ink marks with an ordinary white-board marker and then rub-off with soft rag. Quote
SLA Posted February 11, 2012 Author Posted February 11, 2012 (edited) actually my issue is little more complicated.. this is written on the plastic (you know its not 100% plstic, sort of plastic/rubber, the surface is not that hard). car is a corolla 121.... its like the ink is almost removed, but seems like some amount of ink is like absorbed into the surface.... Anyway I'll try with K'oil and check tomorrow morning. Edited February 11, 2012 by SLA Quote
osanda19 Posted February 14, 2012 Posted February 14, 2012 did u tried with dash board cleaner & dash board polish(wax),i think that this can hide that marks....is that your dash board is beige or black??? Quote
SLA Posted March 3, 2012 Author Posted March 3, 2012 Hi All... I tried everything and nothing worked . Finally I went to a garage and checked with them.. ( It is one of the well known garage in my area) They too tried with few of those chemicals and said that painting the dashboard would be the only solution....seems its like the ink is absorbed little into the surface... Feel its better I keep it as it is...... Quote
rover Posted March 4, 2012 Posted March 4, 2012 If you are parking the car in the sun often it might fade away after couple of weeks. Quote
SLA Posted March 4, 2012 Author Posted March 4, 2012 ya.. thats why I though of keeping them as it is...... Quote
