There are some numbers and letters written on newly replaced dashboard. may be they have written it using a permanent marker or somethin like that... can someone please suggest a dashboard cleaner to get this mark removed.
'SLA',
Can you describe you have letters on the plastic area or on the other leather cloth area.
As for previous post can try k oil if not you have to use Son of a gun dash board cleaner can.
With a old soft tooth brush. Can try Tpol cleaner also.
Sylvi Wijesinghe.
actually my issue is little more complicated.. this is written on the plastic (you know its not 100% plstic, sort of plastic/rubber, the surface is not that hard).
car is a corolla 121....
its like the ink is almost removed, but seems like some amount of ink is like absorbed into the surface....
Anyway I'll try with K'oil and check tomorrow morning.
Edited by SLA
  • 3 weeks later...
Hi All... I tried everything and nothing worked :(. Finally I went to a garage and checked with them.. ( It is one of the well known garage in my area)
They too tried with few of those chemicals and said that painting the dashboard would be the only solution....seems its like the ink is absorbed little into the surface...
Feel its better I keep it as it is......
